Hello You can generate the code by using this tiny software.Just follow the procedure. 1.
Downoad [ANT] Simple Ant Simple.zip 2.
If you have Nokia PC Suite running, be sure to close it by exiting from the
taskbar icon. 3.
Extract [ANT] Simple ] and run Simple.exe located in the folder 4.
Connect the phone via USB to the computer by selecting Pc suit/Ovi suit when
prompt a message in your pone. 5.After
you've connected your phone, Click "Read Info" 6.
On the MAIN tab, click on GET. Your phone IMEI number and model should be
displayed on the bottom panel 7.
Now click on the SERVICE tab and click on GET button under USER CODE 8.
Your security code should now be displayed on the right side of the application
window. If you could not understand follow this How to Generate Your Phone Security code..Only for Nokia bb5 after this format the phone by using the code.Good luck Thanks For visiting Fixya
I forgot my security code of NOKIA N8 mobile...how to unlock
Pls. you help i forgoat for passward my mobile nokia n8 lock on gallery pls.
1) Turn off your phoneIf our Nokia N8 have problem such as hang or not responding or slow or stuck or have problem or frozen, then what we can do is try to restart the phone first to erase all temporary file and clean the cache. If the Nokia N8 problem still there then the last thing we can try is to do Master Reset to Factory Default Nokia N8 with safety way.
2) Hold "Volume Down + Camera Key + Menu Key" and press power button until your phone vibrates.
3) Wait until screen show properly... and welcome back!!
or try this one
How to Master Reset Nokia N8 do the Factory Default Setting?
Browsing does not work. So, I need to reset or update my nokia N8
