2000 Ford Taurus Logo
Posted on Sep 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I was attempting to install a new stereo in my 2000 taurus. it requires to an adapter to put the new stereo in. i got the new adapter and stereo in *kinda* but decided i didnt really know what i was doing, so took the adapter and new stereo out and put the factory stereo back in. I reconnected all the wires and everything correctly, but when i drove my car later, the stereo didnt work, the power windows didnt work, the power locks didnt work and the spedemeter was way off and sometimes didnt work at all. I have no idea what i did. Help?
gerry bissi
Level 3:
  • Ford Master 4,390 Answers
  • Posted on Sep 13, 2011
gerry bissi
Ford Master
Level 3:
Answers
4390
Questions
Helped
3060581
Points
11499
Check your fuses first. You may have blown one.
Visual Inspection Chart Mechanical Electrical
  • Integrated control panel (ICP) physically damaged, misaligned, any control(s) inoperative
  • Digital audio compact disc player physically damaged, misaligned, any control(s) inoperative
  • Antenna or antenna cable physically damaged, misaligned connection(s)
  • Radio speakers, mounting/speaker cones physically damaged, misaligned
  • Radio ignition interference capacitors, radio frequency interference suppression bond misaligned (also check for cleanliness and metal-to-metal contact)
  • Battery junction box (BJB) fuses F127 (5A), F117 (20A), F127 (5A).
  • Central junction box (CJB) fuse F227 (10A) F211 (15A), F216 (15A), F226 (10A) (wagon only)
  1. If the fault is not visually evident, proceed to diagnose the integrated control panel (ICP) by entering the ICP Self-Diagnostic Mode.
NOTE: To enter the ICP Self-Diagnostic Mode, the ICP must be ON and in radio tuner mode (AM/FM).
  1. Enter the diagnostic mode by pressing and holding preset buttons 3 and 6 simultaneously. This will suspend all radio functions, and display SP.
  1. Preset Button 1 = Audio internal/external SELF TEST. The display will flash SELF while gathering the diagnostic trouble codes (DTCs), then stop flashing when complete. Press the TUNE UP button to display the DTCs if any exist. Record codes and refer to the following table:
ICP SELF-TEST CODES Code Description 0 No diagnostic trouble codes logged 1 No response from rear chassis unit (RCU) 2 No response from cassette player 3 - 4 No response from compact disc player 5 - 6 - 7 No response from remote climate control 8 - 9 Read Only Memory Verification failed
  1. Preset Button 2 = Displays the feature strap for code identification, refer to the following table.
Code Description 01 Base-Electronic Search Radio (ESR) with Manual Climate Control (MCC) 07 Electronic Search Radio with Cassette (ESC) with MCC 17 ESC with Electronic Automatic Temperature Control (EATC) 97 Not programmed default of ESC with EATC
  1. Preset Button 3 = ICP and RCU identification. This test identifies the software level of the ICP and RCU. The ICP is tested first, followed by the RCU. The display will have two sequences of three codes each. The first sequence is for the ICP, the second sequence is for the RCU. For code identification, refer to the following table:
Item Part Number Description 1 - Product variant code 2 - Tape model 3 - CDR
SOFTWARE IDENTIFICATION CODES Product Type Code Description Product Variant Code Description 21 ICP 07
08
09
10
11
12 EATC with AM/FM, cassette player and CD changer
EATC with AM/FM and cassette player
Manual A/C with AM/FM and cassette player
EATC with AM/FM cassette player and CD changer 31 RCU 01
02
03 Analog
Digital
Midline 71 Remote climate control 01 LH drive 52 Compact disc/disc jockey 01
02
03
04 Sony® 10 disc
Sony® 6 disc
Clarion® 6 disc
FMS 6 disc
  • gerry bissi Sep 13, 2011
        Preset Button 4 = RCU self test. This test will check the RCU read only memory (ROM) and electrically erasable read only memory (EEPROM) memory chips. For code identification, refer to the following table.
    RCU DIAGNOSTIC TROUBLE CODES
    Code
    ROM
    EEPROM EQ
    EEPROM Seek Var
    EEPROM Stereo Var
    0
    FAIL
    FAIL
    FAIL
    FAIL
    PASS
    FAIL
    FAIL
    FAIL
    FAIL
    PASS
    FAIL
    FAIL
    PASS
    PASS
    FAIL
    FAIL
    FAIL
    FAIL
    PASS
    FAIL
    5
    PASS
    FAIL
    PASS
    FAIL
    6
    FAIL
    PASS
    PASS
    FAIL
    7
    PASS
    PASS
    PASS
    FAIL
    8
    FAIL
    FAIL
    FAIL
    PASS
    9
    PASS
    FAIL
    FAIL
    PASS
    A
    FAIL
    PASS
    FAIL
    PASS
    B
    PASS
    PASS
    FAIL
    PASS
    C
    FAIL
    FAIL
    PASS
    PASS
    D
    PASS
    FAIL
    PASS
    PASS
    E
    FAIL
    PASS
    PASS
    PASS
    F
    PASS
    PASS
    PASS
    PASS
        Preset Button 5 = ICP panel display test. This test will light all segments in the ICP.
    Condition
    Possible Sources
    Action
        The audio unit is inoperative
        (BJB) Fuse F101 (60A), F107 (40A), F117 (20A), F124 (5A).
          Circuitry.
            Rear control unit (RCU).
              Integrated control panel (ICP).
        GO to Pinpoint Test A .
        The audio unit does not operate correctly-cassette player
        Circuitry.
        GO to Pinpoint Test B .
        Integrated control panel (ICP) is in cassette mode, the display flashes ERR
        Three side changes in 10 seconds.
          Defective cassette.
        REMOVE the ICP and SEND it to an authorized Ford audio system repair facility. TEST the system for normal operation after the repair.
        Integrated control panel (ICP) is in cassette mode, the display flashes EJ ERR
        ICP (cannot eject the cassette).
          Defective cassette.
        The audio unit does not operate correctly-response time between pressing any of the ICP buttons and system response is more than two seconds
            Compact Disc (CD) changer.
        GO to Pinpoint Test C .
        The audio unit does not operative correctly-one or more ICP controls is not functional in either radio, cassette or CD changer mode or all modes
            CD changer.
        REMOVE the suspected unit (ICP, RCU, or CD changer) and SEND it to an authorized Ford audio system repair facility. TEST the system for normal operation after the repair.
        The ICP display can be dimmed but not the control buttons, or the control buttons can be dimmed but not the ICP display
        Irregular operation of ICP display and indicator LED
        The audio unit does not display CD changer information
        Battery junction box (BJB) fuse F117 (20A).
          Circuitry.
              CD changer.
        GO to Pinpoint Test E .
        During CD mode, the integrated control panel (ICP) display shows NO CD
        CD changer.
        EJECT CD magazine. CYCLE ignition switch (ON/OFF/ON). If problem remains, REMOVE the digital audio compact disc changer and SEND it to an authorized Ford audio system repair facility. TEST the system for normal operation after the repair.
        Noisy reception
        Antenna.
          Antenna connections.
            Noise suppression equipment.
        GO to Pinpoint Test F .
        Poor quality/distorted sound from one or more speakers (not all speakers)
        Speaker(s).
          Circuitry.
            Audio cable.
        GO to Pinpoint Test G .
        Poor quality/distorted sound from one or more speakers (not all speakers)-low volume
        Speaker(s).
          Circuitry.
            Audio cable.
        GO to Pinpoint Test H .
        Poor quality/distorted sound from one or more speakers (not all speakers)-pop or crackle when driven over bumps
        Circuitry.
          Loose connection.
        GO to Pinpoint Test I .
        Poor quality/distorted sound from one or more speakers (not all speakers)-exhibits hum
        Insufficient noise suppression.
        GO to Pinpoint Test J .
        No sound from one or more speakers (not all speakers)
        Speaker(s).
          Circuitry.
                Antenna system.
        GO to Pinpoint Test K .
        No sound from all speakers
        Speaker(s).
          Circuitry.
              Audio cable.
        GO to Pinpoint Test L .
        Loud popping sound when cycling the ignition switch
          Circuitry.
        GO to Pinpoint Test M .
        No radio illumination
        Circuitry.
        REFER to Section 413-00 .
        The power antenna is inoperative
        Battery junction box (BJB) fuse F101 (60A).
          Central junction box (CJB) Fuse F220 (10A).
            Antenna.
              Power antenna motor.
        Go to Pinpoint Test N .
How do I fix the clock display on my 1999 Pontiac Sunfire?
It appears to be that the radio clock display has malfunctioned, and is due for a replacement radio, which could be an aftermarket or oem radio, maybe found at a junk yard.
Tools required for oem replacement radio, torx keys set.
Before working on the radio or other electronics, disconnect the battery cables with 8mm wrench.
Replacing the oem radio is much easier, if you obtain oem radio, compared to aftermarket radio, due to being direct fit.
The radio is same for 1995 to 1999 Pontiac Sunfire and the Chevy Cavalier, regardless of sub models, such as SE,GT, VL,VLX,Z24. etc.
Parts needed for the the aftermarket radio install :Stereo assembly, stereo wiring harness adapter, radio antenna adapter, and dash install kit.wiring diagram for the wire colors / functions, along with tools, such as torx key set, screwdrivers,wire crimper, wire stripper, double ended wiring connectors, hair dryer.
The oem stereo removal video is for the 2000 to 2005 Sunfire / Cavalier, but are the same or very similar procedures.
Link to oem stereo removal procedures.
Pontiac Sunfire Radio Repair and Removal 2000 2005
Link to aftermarket stereo install / connect procedures. ( Sunfire Video )
HOW TO INSTALL AFTERMARKET STEREO PONTIAC SUNFIRE
Link to aftermarket stereo install / connect procedures. ( General Video )
How To Install Car Stereo Single Double DIN Car Audio 101
Have a nice day.
F5TF-19B132-BA Ford Radio Pin out
The stereo pin layout can be obtained from the car dealership, also a repair manual should have the stereo wiring harness layout in it , the stereo harness adapter for installing non oem stereo, found at the local auto parts store will come with the wiring layout, wires are color coded too, sometimes the stereo harness or stereo harness adapter will have small writing on the wires itself, showing you what that wire is for, and where it should connect.
Basically it comes down to, obtaining the stereo wiring layout, read the description on the wires, and properly connect them together, then solder the wires or crimp them, I like to solder mine with soldering wire for electronics, and put shrink tubes to protect the wires, put the shrink tubes on the wires before soldering together, and ensure the shrink tube is the proper size awg wire gauge.
You will also need, aftermarket face adapter kit and antenna adapter, if installing aftermarket stereo.
Hope this helps and enjoy the stereo :)
1helpful
How do ihook up a new car stereo to my 2000 dodge slt quad cab wit 4speakers with crossovers how do i find the wireing 4 all the audio systerm
Go 2 auto zone or any stereo shop and get a factory wiring Harness adapter 4 youre year and make it will plug in and Will be color coded and labled for easy install remember U will need a adapter plate 2 for aftermarket radio 2 fit Factory hole each will run u about $20.00
I want to connect an mp3 player but i only have a cd player, is there a line-in jack somewhere in the car or behind the stereo
No jack on factory stereo. You'll have to use either a cassette adapter or an FM adapter; both plug into your regular mp3 line out. Cassette adapters are not as reliable but cheap and don't use power, while FM adapter requires power (from 12V or battery) and is more expensive.
2000 Ford Taurus - Installed a new radio and used the Meta 99-5716 install kit with wiring harness. After install, radio, pwr windows, pwr locks, dome light, windshield wipers, and speedomoter have stopped...
Sounds like you have blown fuses which could have happened if you accidently short circuted something while wiring up the new stereo. Check your fuses to see if any of them are blown.
4helpful
2answers
2002 Taurus stereo
Here are the factory wire colors, please rate this solution to your problem, a note any stereo store that sells auto decks has adapter wiring harnesses to do a direct plug in of your DIN standard radio you are trying to install, no cutting of the factory harness, they are cheap
2000 Ford Taurus Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Black
Car Radio Accessory Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Blue/White
Right Front Speaker Positive Wire (+): Tan/Green
Right Front Speaker Negative Wire (-): Green/Orange
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Blue
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Black/Violet
Right Rear Speaker Negative Wire (-): Orange/Violet
Installing after market stereo
Dave,
You will need to go buy a wiring harness adapter from your local Walmart (usually cheapest there) or Local Electronics place (ie Best Buy). The wire harness that goes out from the radio goes into the Adapter and the adapter plugs into the car harnesses. Also these Adapters come with the wiring diagrams for your vehicle. They typically run 10 - 15 bucks depending on where you get them. Thanks for using FixYa!
Sincerely,
JC
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
