Computers & Internet Logo
Posted on Sep 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sir i lost my key code for power dvd 3.1 - CyberLink Computers & Internet
Anonymous
Level 2:
Sergeant:
  • Expert 211 Answers
  • Posted on Sep 12, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
211
Questions
Helped
32312
Points
545
I believe they now have version 11 available, 3.1 may no longer be supported! I would contact them (Cyberlink) to see if they still have your records when they issued your number or when you registered on line.
Also ask if they provide a easy way to upgrade for a reduced price.
1helpful
2answers
How to reformat e5
Sir,*,3 green not working for nokia e5 mobile and also not working shift ,space,back space har reset plz tell me another one
1helpful
I'm lost key cd my cyberlink power DVD 5.0 P/N : 6-26-M5SS3-V20
Sorry, but we are not a warez site.... We don't give out activation keys or password codes.
6helpful
2answers
Lost my nokia x2 code how can i reset
try to format File System your phone with this way :
1.Turn of your phone
2.Hold down Key > Green/Call key + * + 3 + Power Button at the same times until turn on and still hold the key in 5-10 Second and Realese it.
3.If the phone show the Regional Setting like Country,Language,etc
than mean your phone is Done to Unlocked.
- But all in your Phone memory (internal memory) willbe erased.
Can i asked the hard reset code of my nokia 6233 . thanks a lot sir .
Hello
*#7370# .......... Format phone...[Hard-Reset]
*#7780# .......... Factory Reset
if that doesnt work in case you lost your lock code, try:
Turn phone off, press and hold the green (talk) key on the left + number 3 on the keypad + the * key + the on button.
good luck
15helpful
3answers
I forgot the lock code of my nokia n82 phone. how can i format it without knowing the lock code? please help me...
follow this but you will lost all the contacts, so try making a backup before proceeding,
Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
1helpful
2answers
I lost my key code for the PowerDVD 5.0. Can you
You should worry for this kind of problem . i am here to help you. Login to the website www.serials.ws and search for the serials of power dvd 5 then you will get the list fo serials.Choose one with maximum rating and use to unlock your power DVD
16helpful
3answers
Lost key code for installing power dvd onto my pc
try this key code it should work
bx36m15491914915 i had the same problem it worked for me
Lost my key code
press (input) the pp button on the remote 3 times press ok and it should be ok.then go into setup/function/lock and disable lock!
Thanks,
Melcom
23helpful
4answers
Cd keys Samsung power DVD XP V4.0 set up
Your software cyberlink power dvd 4.0:
S/N: mv3938m659859834
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
1helpful
Need dvd code for symphonic WF104 I am using a scientific atlanta remote control
I'm guessing you have tried these already, but, you can try:
2017, 2213, 1029, 1134, 1150
if it is the ER1
014, 186
If that doesn't work, try a search by doing this:
Turn on the device.
2. Press and hold SELECT and the appropriate mode key (CBL, TV, VCR, DVD, or
AUX) until the mode keys blink twice. For example, to search for a TV code, press
and hold SELECT and TV at the same time.
Note: If you reassigned mode keys, you may, for example, press SELECT and
VCR to search for a TV code to assign to the VCR mode key.
3. Press 9 9 1. The mode key you selected in step 2 blinks twice.
4. Point the remote toward the device, and press PLAY . The remote automatically tests each code in its library, beginning with the most common codes. The mode key blinks once each time the remote transmits a new code. The mode key
blinks twice when it reaches the last code.
5. As soon as the device powers off, press SELECT.
6. Verify the new code is correct by pressing POWER.
7. Did the device power on again?
• If yes, press SELECT to assign the code.
• If no, complete the following steps:
a) Turn the device on.
b) Press channel up or channel down to step forward or back to the correct code.
c) When the device turns off, press SELECT to assign the code.
Top CyberLink Computers & Internet Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a CyberLink Computer and Internet Expert? Answer questions, earn points and help others
