My Grandson dismantled my Wife's New Home L-373 needle foot. The problem was a simple bent needle. Now, I don't have a diagram for re-assembling the parts on the shaft.
Larry
Http://www.brewersewing.com/special/sewing_parts_manuals/l372.pdf
Here is the pdf for the whole parts diagram. Everything is on there in detail. If you still need the owners manual that would have to be purchased from a website as it is not available online or by the manufacturer. If you have a moment to accept and rate this solution it would be greatly appreciated as I strive to provide fast, accurate, and economical solutions.
Thanks,
Lee
Hi
U can get the diagram for this site
http://www.powertoolspares.com/bosch-diy-tools-spare-parts-1/6000552/bosch-belt-sanders/6000623/belt-sander-pbs-75-a-spares/0603270103/0603270215.php
Thank you
The manual will be more than enough to reassemble the parts
you can get the manual from the link below
manual link
If you already own it just go through the manual
Thanks for using Fixya
SAM ANDERSON
Sewing Machine Maintenance
Needle Faces Where?
I Need to Tighten the Tension....
Changing a Needle
Need Help
Basic Questions-
Bobbin Assembly Popped Out!
Do You Think My Machine is Fixable?
How to Change a Broken Needle
Needle Bar Adjustment
Oiling an Elna 3007
Getting the Timing Belt Off?
What Size Needles for My Machine?
How to Oil my Machine?
Where to Oil??
Stitch Length Knob Woes
Can't Seem to Put the Bobbin in Correctly
Timing Belt Tension
Adjustments
Running Very Slow-
Oiling Points on Singer 257
Oiling My Singer Touch & Sew
Singer 457
Featherweight Case Odor
Brother XL2010 Q's
Does My Machine Have More Than One Belt?
Cannot Seem To Adjust the Tension
What to Do About a Gumming Up Needle
How Tighten My Bobbin Tension, Please
Is it Covered Under Warranty?
Proper Threading Instructions?
Just a Foot Pedal?
Simple Threading Instructions for a 1036
Threading a Singer 600
Replacing a Blade on a Johnson Ruffler
Changing the Needle
Lubricating a Singer 1036
Thread Balling Underneath
Warranty Info
Machine Covered in Hardened Oil
Spindle Stuck?
Do Motors Die?
Singer 457
Brother Sewing Machine
Servicing My Machine-
Belt Replacement
Lubricating My Sewing Machine
just click on the link
Needle Faces Where?
Changing a Needle
Need Help
Basic Questions-
thanks
I haven't received ANY assistance at all. Please contact me.
I need a diagram of the parts assembly on the needle bar for my New Home L-373 sewing machine. I have all the parts but don't know how they fit.
