Yesterday I turned off my Nokia e63 device. When I tried to turn it back on I held down the power button until it vibrated as normal, the centre light came on as normal however the screen stays black and it won't turn on. I've tried recharging it thinking it could possibly be a dead battery but that hasn't worked I've also tried to plug it into my computer and that hasn't worked. I've also removed the battery several times as well as the sim card but nothing seems to work.
Any help would be greatly appreciate
Do a Full Reset THIS WILL DELETE EVERYTHING!!!!!!!
Press and hold the Volume down and Power buttons at the same time until you feel a vibration (about 10-15 seconds).
When you feel the vibration, immediately press and hold the Volume down button until you see a large exclamation mark.
Once the exclamation mark appears, press the following four buttons in this order: Volume up , Volume down , Power , Volume down . Your phone should now reset and restart itself. (It might take a while for the reset to finish.)
Try holding volume Up and volume down together then the power button----hold all three until vibration starts.......that should get you to a factory reset.
1. turn off your nokia lumia 2. then press power off button,camera button and volume down button until it starts vibrating 3. when it vibrates leave power off button but dont leave camera button and volume down for more than 10 sec
If it has a CD/DVD drive, and you have a 'startup disk' or similar utility disk that may have come with the system, you can put the CD in the drive, and see if it will boot from there. Normally holding down the 'F12' key will give you the menu to choose which device to boot from.
If you're not comfortable trying that type of thing, it's probably best to take it to a repair center.
Quoting "SRALPH" from HowardForums.com http://www.howardforums.com/archive/topic/779306-1.html
With the power off:
1) press and hold the volume down button, which is the closest one to the mic
2) with that button held, simultaneously press and hold down the power button until the blue led flashes.
This will deactivate the vibrate function and it should stay
deactivated until you power up the headset with the volume up button
pressed and held in during power up
Call vibrate*
• Call vibrate is automatically activated when you turn on your headset.
• To disable the call vibrate feature, press the answer/end button and
press the volume down (-) button at the same time.
• To reactivate the call vibrate feature, press the answer/end button and
press the volume up (+) button at the same time.
