Computers & Internet Logo
Anonymous Posted on Sep 12, 2011
For motherboard KOB 810 FCST 1. Please let me know position of BIOS write protection jumper. 2. If please send me reference manual of this MB.
  • Anonymous Sep 22, 2011
    When I tried to use the above linkhttp://www.mercury-pc.com/downloads_list... I ended in the message
    "Forbidden
    You don't have permission to access /downloads_list.php on this server.
    Apache/2.2.3 (Red Hat) Server at www.mercury-pc.com Port 80"
  • Anonymous Nov 19, 2011
    Thanks. I could download the manual today.
Hans Pedersen
Level 3:
  • Mercury Master 3,606 Answers
  • Posted on Sep 12, 2011
Hans Pedersen
Mercury Master
Level 3:
Answers
3606
Questions
0
Helped
2230908
Points
8683
Hi, you can download a manual and drivers here:
http://www.mercury-pc.com/downloads_list.php?productid=55
You may have to unzip the file before you can read it.
Mercury KOB 810 FCST motherboard panel connection diagram
Hello it look like this:
http://www.mercury-pc.com/download/uploaded/drivers/
You can also try the mercury homepage:
For downloading the manual and drivers.
Please unzip the file and you need adobe reader to read the content.
Good luck
1helpful
I get a pb with BIOS. I change the battery of BIOS and now I can not even acceded to BIOS : DEL doesn't run. I change jumper for ten seconds : not better DEL doesn't run. Yesterday the bios charged...
1 or 2 things going on here, I'm assuming the jumper was your reset jumper (Please refer to your motherboard manual for location).
Assuming you have reset the jumper and no Bios is either a dead CPU or Motherboard. You can normally test if the motherboard is bad if this does not beep (again make sure you speaker on JPR Configuration is correct if no motherboard manual please refer to URL : https://www.manualslib.com/manual/444298/Asus-P4p800.html
2answers
When i start PC; BIOS seting opens and says clear
  1. pls read the user manual first to identify which pinds of password jumper to normal position
  2. Reinstall the jumper in a different position. For example, if you removed the jumper from pins 2 and 3, reinstall the jumper over pins 1 and 2.
  3. Replace the computer cover and reconnect the power cable and monitor.
You can now assign a new system and/or setup password. For more password information, refer to the Passwords section of your computer'sservice manual.
4helpful
3answers
Unlock dell inspiron 1521 unknown bios pswd
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-1521-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
1helpful
Hi I forgot my password for toshiba satellite 205 cds , for bios . What I can do ? Please HELP Emanuel
You can reset bios password with 2 method.
(1) open back cover of laptop then find motherboard .Pull cmos cell from motherboard for 15 minutes then again put it in it's position .then it not ask for password.
(2)You can clear password with jumper settings find jumper on motherboard named clear cmos it has 3 pin .1-2-3
Put jumper in 2-3 position then again put it in 1-2 position then check .
Let me know if you need more assistance.
Thanks.
Turn off power and reinstall the jumper in normal mode position in intal(lga775)
if this message is appearing on your screen then the bios jumper is installed at reset position. so please install this bios jumper of your motherboard and the pin number 1-2 position of bios.
it will be allright
1helpful
Mercury KOB 810 FCST motherboard connection diagram
The link below will take you to a page where you can download the manual for the MB:
Good luck and please let me know how it works out for you.
2helpful
2answers
Intel d945gnt
Yesterday night i resove the problem with the intel by many e-mail.
For all guys that have the same problem , the solution is:
1- put the jumper in position pin 2 and 3.
2- turn on the PC with jumper in the same position ( pin 2 and 3)
3- the bios start in "recovery mode"
4- deselect the memory "aggressive mode"
5- save bios setting, then power off the PC
6- set bios jumper in position 1 and 2
coolhandan thx for attention and please insert this solution in intel D945GNT archive for future customers that fall in same problem. Sorry for my bad English ;) THX at all
BIOS update (motherboard GA-6BX7+)
Please disable "BIOS Flash Protection" function in the BIOS or by Jumper. About the details, please refer to your motherboard manual.
refer to page 22 of THIS manual
If you "search" the word "flash" there are many references that may be of assistance if the jumper does not resolve issue for you
Top Mercury Computers & Internet Experts
Jose Ramirez
Paul Bade
Grand Canyon Tech
Grand Canyon Tech
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
