Question about Nor-Lake Freezer Norlake Refrigeration 6' x 6' Kold Locker Walk-In Freezer - 6' 7'' High w/Floor
Please help. Have norlake. Model klb66cl temperaturereads 10 degree farenheit.is it okay. Need to bring it down. Is it copressor problem? Help.. Thanks.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 40 Answers
If the temp is 10f compressor is fine, just need a tune up, call a specialist.
Posted on Nov 15, 2013
4 Suggested Answers
SOURCE:
roadbird383
  • 40 Answers
SOURCE: How do turn the temp up on a norlake walkin?
They are usually mounted on the front panel of the evaporator or mounted on the wall behind the evaporator.There is a possibility that the temp. control is at the condenser,and the sensing bulb was slipped thru the wall.Look for the bulb at the back of the evaporator and follow the cap tube.
Posted on Dec 05, 2007
22yooper
  • 828 Answers
SOURCE: walk-in norlake freezer
Check the evaporator coil for frost buildup on the back. Check for frost on the suction line, the biggest line returning to the compressor. If frost is evident at these places you have a defrost system problem. These systems have a defrost timer that defrosts the coil at preset times. Check the timer for proper operation by marking the position of the dial and check back to see if it changes. If it does not change position the timer motor is most likely bad. If the dial is not rotating automatically you can manually turn the dial in the direction of the arrow and put it through a defrost cycle.
Posted on Sep 14, 2008
  • 358 Answers
SOURCE: we have norlake walk in freezer and the problem is
You have to defrost the coil by turnning of the unit and to make it faster leave the inside fan/s running.But if it's building up ice and the fan/s inside works ,is most probably that the unit is low in refrigerant(freon) , or the defrost system is not working.
Posted on Sep 25, 2009
What should the freezer temperature shouls be????????????????
Normally, freezers are at 0 degrees. If you have ice cream, shoot for -10 degrees.
hope this is what you are looking for.
Feb 21, 2010 | Nor-Lake Freezer Norlake Refrigeration 6'...
Norlake freezer 6x6 not freezing enough
Normally freezers are kept at zero. Most health departments will not allow the temp to be higher than plus 10. If you want to store ice cream, you need to be at minus 10 degrees to minus 15 degrees.
let me know if I can be of any further help.
Sep 29, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
We have norlake walk in freezer and the problem is buildup ice and the temp is 35degree right now how to bring the temperature back to zero degree
Sep 25, 2009 | Freezers
Freezer is not freezing it is staying on 30degree
The defrost system has failed and is not de-icing the coil or, the door is not sealing tight or too much time open allowing excess humidity to enter the chamber, thereby overcoming the capabilities of the defrost system. The system has a defrost timer someplace, check to see if it is running. If not, you can probably advance it into a defrost cycle with a screwdriver. (turn the shaft slowly until a click is heard and the system stops) Allow 20 or 30 minutes for the coils to defrost, and restart with the screwdriver if it has not took off on it's own. If the timer is found not running, replace it.
May 25, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Need to know breaker and wire size to run from panel
Compressor 12/3 with 20 amp dual pole breaker. 220 VAC
Freezer 12/3 with 20 amp single pole breaker 120 VAC
May 24, 2009 | Nor-Lake Freezer Walk In Freezer 6ft x...
Temp -35 degrees,freezer runs all the time
I assume there is no manual control for setting temp. so the thermal sensor or control circuit has failed and it is just staying at its maximum.  You will probably get more help from the manufacturer but their website is somewhat disjointed; looking for contact info for your product ends at one point and then shifts to their scientific product line.
The only general contact info I found is here:
Nor-Lake
You will in any case need to have the correct model number at hand since the subject line doesn't sound like your freezer.
Apr 02, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Freezer tempature
Depends on the product you want to keep in the freezer. Usually you want to try and stay between 0 and +10 degrees for most items. Ice Cream must be -10 degrees minimum. Any warmer and it won't keep. Hope this helps.
Good Luck
Dec 24, 2008 | Nor-Lake Freezer Norlake Refrigeration 6'...
Walk-in norlake freezer
May 25, 2008 | Nor-Lake Freezer Norlake Refrigeration 6'...
Dec 05, 2007 | Nor-Lake Freezer Norlake Refrigeration 6'...
Freezers Logo
133 people viewed this question
Top Nor-Lake Freezers Experts
Dennis Boxerman
Steve Allison
Steve Allison
Are you a Nor-Lake Freezer Expert? Answer questions, earn points and help others
