Sewing Machines Logo
Posted on Sep 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a foot control and plug, any suggestions
Debbi's Sewing Machine Repair
Level 3:
  • Euro-Pro Master 7,365 Answers
  • Posted on Sep 12, 2011
Euro-Pro Master
Level 3:
Answers
7365
Questions
Helped
1744350
Points
19451
Try these sites
sewingpartsonline.com
sewvacdoctor.com
whitesewingcenter.com
sewingpartsdirect.com
sewingsupplywarehouse.com
sewforless.com
2answers
The machine is like new but the machine wont start with the foot pedal I have changed the fuse on the plug but the pedal is not working could it be something on the machine
I suggest taking it to a technician. He can check whether there is power from the foot control to the machine or even check the machine with a different foot control unit. That will probably indicate where the problem is so you will know if the foot control needs repair or replacement or it is something in the machine.
Viking rose 609 model foot pedal will not work
I would suggest you replace the foot pedal speed control.
What to do when foot pedal just stopped working on old Bernina 830
There are a few problems possible. Assuming that there is not a mains (house) power problem, use the following logic to sort out the problem:
1. Do you have a light (assuming that the light bulb is good)? continue to #2.
2. With the machine unthreaded, the presser foot up, and the power cable plugs fully plugged in at the motor and foot control, depress the control to the run position.
Carefully bend and wiggle the cables at the plug locations one at a time. If the motor runs, the cable wires are damaged so you will replace the cable.
3. If available, try a (known good foot control) from another Bernina 830 of that exact vintage.
If the test foot control runs the machine, replace your foot control. Note: If the foot control is a type 213 for very old models, suggest that the control be replaced with a two wire electronic phase type control. (requires the foot control plug end to be cut off and rewired to the new phase controller). These electronic phase controls can be purchased from EBAY. Stay away from the Bernina type 213 control if possible. The type 213 controls have not been available for many years and it is highly likely that these controls are in a used condition, so you will not know if it has been properly adjusted.
If the 830 is a later model machine with the type 232 or 290 foot control and it is determined to be defective, no problem as they can be repaired.
4. If the (known good foot control) still does not work, you can assume that the motor has a problem. Motors for the Bernina 830 are occasionally available on EBAY and other sources.
Note: If the motor brushes have worn out and the commutator has been damaged, the motor is also salvageable.
Note: Always unplug the machine from the mains power when not in use as per Bernina instructions.
SewTechnical Home
VX808/Vx809. When put pressure on foot control stop motion contro doesn't move.
I would suggest that the machine needs to be serviced to find out why it not responding the way it should.
2helpful
4answers
What is err code F04
It most likely is your foot pedal. Unplug your foot pedal and start the machine without it. If it works properly without the foot pedal plugged in then your foot pedal needs repaired or replaced. This worked for us with the NX400 machine and I am sure the NX450 is closely similar. Don't bother to buy a Manual if you didn't already get one with the machine. A Service manual and parts manual is best; But just so you know they don't show the error codes unless you are a qualified and authorized repair person for the machines. I got my info from the repair man where my wife buys and repairs her machines. I am an electronic technician and mechanic so I understand how this system works. I will be repairing my wife's machines from now on.
6helpful
Old model Bernina 830, running ok, then kept running, won't stop. disconnected cord, disconnected foot control, plugged cord into motor, motor runs without foot control. Reconnected foot control, motor...
There is a thing called a suppressor which is normally located in the foot control which has fused, you need to open the foot control and you should see a a small thing that looks liuke a fuse connected to the two terminals which you need to take out and discard because you don't need it any more, if you don't have on in the control then it will be on the motor which means you will have to take it in for repair.
3helpful
4answers
Power won't stop - Husqvarna/Viking 3600
your foot controller is damaged and should be replaced.
Top Euro-Pro Sewing Machines Experts
Mike Cairns
Mike Cairns
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
