On the back panel of the opener itself is a small pushbutton. Press the button and the indicator near it will light. While the indicator is lit, enter the new 4-digit code on your keypad and it will be set. (You are actually programming the receiver with the new code this way. The wireless keypad doesn't store a code.) The programming light goes off on its own.
what keypad are you using with new opener? Frequency has changed. can't use old one. you probably never needed to change things; just needed to follow proper coding procedures.
I had the same frustrating dilemma with my Craftsman LiftMaster garage door and Keypad, Model 139.53754-01 (dated 10/06; and has the # 315 MHz).
To resolve “the dilemma”, grab your keypad, climb up on a ladder to access the garage door opener’s motor unit. On the right side of the motor unit, remove the white plastic casing by pressing buttons on each side and pulling down. This will expose the programming area, and for our purposes, the “Learn” button.
1. On the motor unit, press and release the “Learn” button. The Learn indicator light will glow steadily for 30 seconds.
2. Within 30 seconds, enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold the ENTER button.
3. Release the ENTER button when the motor unit lights blink. The code has been “learned”/stored/activated.
Good Luck, and I Hope this Helps! Gail For possible future reference:
How to change an existing, known PIN (Changing an existing PIN can be done with the wireless remote keypad, and does not require access of the motor unit.)
From the keypad:
1. Enter the four digits of the present PIN, then press and hold the # button. The opener light will blink twice. Release the # button.
2. Enter your new 4-digit PIN and press Enter. The motor unit lights will blink once when the PIN has been “learned”/stored/activated. Test by entering the new PIN, and pressing Enter.
