SOURCE: epson epl6200l photoconductor dirty
when i am printing a small dots black appear.. what is the problem? photoconductor unit? were can i buy one here in the philippines?
SOURCE: Lexmark E250dn laser printer
Reinstall the drivers and see if it works.
Otherwise unplug the printer from the power and leave it without power for 10 minutes. Than plug it back in and let me know if it helped.
SOURCE: Color prints have two strips of toner that will rub off.
Fixed the problem with the advice of one of your members!
Thanks
SOURCE: Lexmark E232 photoconductor
Make sure to install the new photoconductor 1st.
1) Power off the printer using the switch in the back.
2) Open the front cover.
3) Press and hold the Continue button (Big silver button with Diamond shape symbol) and power the printer On (turn the switch back to ON).
4) When you see the last light i.e. error light on solid, release the Continue button and close the front cover.
5) When you close the cover you will see all the top 3 lights on solid.
6) Press the cancel button with X symbol for 4 times very slowly till you see toner low light (i.e. second light from top) on solid.
7) Press the continue button and wait until you see the light sequence.
8) Press the cancel button and wait until you see the light sequence.
9) Finally power off the printer using the switch in the back (IMPORTANT= wait 1 minute) and power it back on to exit the configuration mode.
SOURCE: PAPER JAM
The problem sounds like your rollers have lost their grip. Remove the paper tray and tip the printer up. Push the red lever on the left of the printer down and you will see the feed mechanism with two wheels. Remove the rubbers on the wheels and turn them inside out. Replace them on the wheels with the worn side now inside and the 'sticky" side out. You should get at least another couple of years worth of use before you need to replace them.
The light is second to the right is Toner Low. If ! and toner low displays a flashing light it means that the photoconductor kit is full and must be replaced. The printer will not print any more pages until the photoconductor kit is replaced.
Press and release Continue button to print a photoconductor kit instruction page. If the light is still blinking, replace the photoconductor kit.
For further assistance, please call Lexmark Technical Support.
