Question about Razor E100 Electric Scooter
I have a Razor e100 that was working perfectly fine but we moved and put it in storage for 9 months. now, it won't take a charge. resetting it didn't do anything either. Does it need new batteries or could it be something else? Also, what compatible parts could I order to make it faster? THX! Rik
    New Friend:
Did u chek the belt
Posted on Dec 25, 2011
SOURCE:
How long does it take to charge Razor E100 Electric Scooter - Red
You threw away a perfect scooter you idi0t. Needed to desulfate battery with a smart charger. M0ron.
Sep 14, 2012 | Razor E100 Electric Scooter
Tip
How to extend the battery life of Razor Scooter Batteries
You can extend the life of your scooter's battery if you take proper care of it. Most people report trouble in getting more than a year or two out of their razor scooter battery set. This is actually a common problem with vehicle batteries.
  • Keep your battery charged
It is recommended to keep your battery fully charged to avoid the build-up of sulfate-ion inside it. Sulfate-ion accumulates when the battery is in a discharged state for a long time.This is the most common reason of premature depletion of lead acid batteries. This can be easily avoided if the scooter battery is kept in a constantly charged state.
  • Charge you Razor Scooter Battery during the Off-Season
Even if not used Sealed Lead Acid Batteries will self discharge over long periods. This will leave the battery in a not fully charges state which will enable the sulfate-ions to build up inside the internal plates which will slowly deplete the battery's capacity. In order to prevent that, you should charge the razor scooter battery at least once every three months when it is not in service.
  • Use a Battery Tender
Battery Tender chargers are a great way extend the life of your SLA batteries as they are designed to fully charge and maintain a battery at proper storage voltage without the damaging effects caused by trickle chargers.
References:
Battery Maintenance 101 How to Extend Battery Life of Razor Scooter...
BU 804b Sulfation and How to Prevent it
Deltran Battery Tender
on Jun 19, 2015 | Razor E100 Electric Scooter
My razor dune buggy won't drive
are you sure that the charger is putting out enough volts to charge the batteries? check the charger with a multimeter, then check the batteries with a multimeter, and viually inspect the batteries for bulging
Apr 28, 2012 | Razor Dune Runner 350 Go Cart
E100 scooter wont run. Battery fully charged, 24v across terminals. Motor runs fine when connected directly to battery power. On-off power switch, breaker switch, brake unit switch, accelerator all checked...
It is possible the new controller is defective, however just because the voltage is showing 24v it may not be outputting the correct amount of amps so don not rule out batteries before checking the following:
To test a battery you need to 'load test' so (with help) connect the battery directly to the motor when weight is on the scooter to see if it will still pull.
Please also remember that you do have to push the e100 to 3mph before starting (many users do not know or forget this step)
Jul 04, 2011 | Razor E100 Electric Scooter
I have two electric razor 175 and put new batteries in both of them. After fully charging them all i hear is a click everytime turn the throttle but nothing,, anyone that can help please help
Thank you for choosing FixYa, I will be helping you today :)
When using an electric scooter, it's always important to know that you must advance on the scooter manually, and during this action, only then can you turn the throttle. The engine on an electric scooter is not powerful enough to move a person by itself.
Hope this helps, thank you :)
Jul 03, 2011 | Razor E100 Electric Scooter
How can you fix a e100 razor electronic scooter when it wont move?
Fitted New on and off switch also new reset button. Battery ok but will not start
Nov 14, 2010 | Razor E100 Electric Scooter
When i try to drive my E100 scooter it doesnt go but when i press on the light turns on and i checked the wires its all there any help please???
have you tried to push the scooter like a normal non-electric scooter then while moving twisting the throttle? If not, then i dont know what to tell you except to get a new one.
May 01, 2010 | Razor E100 Electric Scooter by
Razor E100 reset button and no charge
Hi... My son hasnt used his Razor E100 for nearly a year as couldnt find the charger.. I finally found it and as soon as I plugged it in the plug was showing green light as that it was fully charged... When we turn the unit on it lights up but its dead... Where can I get the cheapest battery (and does it have 1 or 2)? Or you mention a reset button? Many Thanks...
Jan 24, 2010 | Razor E100 Electric Scooter
On an E 100 Razor scooter, the battery charger shows charged
We had the same problem that I found to have a very simple fix. It seems all that needed to be done was hold in the reset button a few seconds while the battery charger was plugged in and the light on the charger turned to red and the battery charged again. Seems like too easy of a fix but it worked for my kids scooter.
Jan 25, 2009 | Razor E100 Electric Scooter
Razor E100 Electric Scooter Logo
257 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
William Erickson
Are you a Razor Toy Expert? Answer questions, earn points and help others
