My Whirlpool GHW9100LW1 front loader washer machine has a problem about every three weeks or so. Water does not completely drain out of the tub and spills out onto the floor when the door is opened. How do you fix this problem?
Yes very helpful, and the picture is awesome deborah
Found the tip on another thread of this site. Remove the 3 star screws located below the access panel that's below the door and clean the trap/filter to the left of the pump. Don't do like me and try to empty as much water first or you'll have an inch of water in your laundry roon when you twist off the cap.
My problem is similar except that when my washer is not in use, the tub will fill up with water (occasionally) or when sitting idle for prolonged periods. I suspect a faulty inlet valve but am not sure. Suggestions??
About three minuteds into the wash cycle the machine stops and a single "F" displays with no number on the error ind. Pushing the reset the machine will continue through the cycle until 11 minutes is left of the cycle and it stops. I must put the select switch to rinse-drain to finish the load...any ideas what kind of problem I'm looking for?
