Electrical Supplies Logo
Posted on Sep 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am replacing a Lightolier 3-way Dimmer switch with a Leviton IPI06-1LX Dimmer switch. When I install the dimmer switch it works fine. But the on/off regular wall switch won't turn the light on or off with the Levition dimmer in place, yet it works fine with the Lightolier dimmer. Do I need to purchase a Leviton brand on/off wall switch to work with the Leviton dimmer?
Anonymous
Level 2:
Novelist:
  • Expert 107 Answers
  • Posted on Sep 12, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
107
Questions
0
Helped
46347
Points
155
It depends. Some dimmers are considered "smart dimmers," where the control on the other end of the 3-way has to be intelligent enough to send a signal back to the dimmer. If the Lightolier dimmer was a smart dimmer, then chances are that the 3-way control was designed to talk only to that specific dimmer. The Leviton product you replaced it with is a simple, basic dimmer - it should work in conjunction with a simple, basic 3-way switch.
If the 3-way control already IS a simple, basic 3-way switch - then I would simply re-check the wiring of the dimmer you replaced.
1helpful
How do I replace a 3 way switch with dimmer?
To replace a three way switch with a dimmer, you need to use a three way dimmer.
Locator Light not working on leviton 6633-pl
6633-pl is single-pole and 3-way dimmer made for max 600 watt incandescent or halogen load. This dimmer does not work for CFL or inductive loads such as motor.
I have no idea what a 'locator light' is?? Do you mean the LED indicator that shows when power is connected?
Troubleshoot section of manual does not show any solution for LED malfunction.
Contact Leviton for email tech support:
http://www.leviton.com/OA_HTML/SectionDisplay.jsp?section=37619&minisite=10251
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
Lightolier 3 way remote wiring
If you have determined the wiring to be correct, then yes, the remote is probably defective..
According to Lightolier literature, your Lightolier OS600 is called a "strap dimmer". Having 540W on a 600w rated switch is pretty close to the limit (90%) of the switch, and will cause the switch to fail sooner than say a 300w load. The 600w rating of the switch applies only if all the heating sink fins are in place. Often times, when installing in a box with another switch or dimmer, fins must be removed to allow the switch to physically fit. If any fins are removed, the rating of the switch is reduced. Page 30 of the manual shows that a 600w strap dimmer that has a single fine removed is reduced to a 500w capacity dimmer, and if both fins are removed, it is reduced to a 400w dimmer. You may find that you will need a 1000w dimmer to reliably gain control of your 540w load, as it will control 600w even with both fins removed. This derating is required due to the heat created by the dimmer. Heat is a killer for electronics, and solid state dimmers are no exception.
Check out page 32 of that manual. On it, are wiring diagrams for dimmers and switches. I believe your is figure "G" that shows the 120v "hot" (black) connected to the black wire of ALL switches, the yellow wires of ALL the switches are connected together, but are not connected to anything else, the 120v neutral (white) connects to the MASTER white wire AND light fixture white wire and finally, the MASTER red wire connects to the light fixture black wire.
It is also important to note that these switches are for standard tungsten incandescent and quartz halogen lamps ONLY. They are NOT suitable for CFL, Fluorescent or other types frequently found in commercial / industrial buildings such as neon or other gas lamps such as Metal Halide, Mercury Vapor, High Pressure Sodium, etc.
I hope this helps & good luck!
1helpful
I can't get the yellow wire of the dimmer slider to work properly using a conventional 3way switch on the other side. I do have the slider on the load box. Could it be that i need a Lightolier ZPR-3 on the...
Most of this style lightolier product requires the proper remote such as the zpr3. Leviton illumitech is a similar design, but uses regular 3 way wiring.
There are others out there as well, that do not require the remote.
What Dimmer can I use That looks like an OS600 but is for a GU24 Dimmable CFL
Depending on your wiring, as to single pole (one switch location) or 3 way (two switch locations) you can use most dimmers. Leviton and Lutron have similar dimmers, and some specifically for cfl's.
Leviton has Sureslide, Illumitech, True Touch
Lutron has Diva, Skylark, and Lumea
Make sure your cfl is dimmable.
I AM REPLACING A 3 WAY WITH A LEVITON TRUE TOUCH 3WAY DIMMER. IT APPEARS AS THOUGH THE OTHER 3WAY IS ACTING AS A SWITCH FOR THE DIMMER. IF THE OTHER SWITH IS "ON" THEN THE DIMMER WORKES FINE...
The other switch should only be changing from one wire being hot when it is in the up position to a second wire being hot when it is in the down position. Then the new dimmer should be hot on one terminal when the other switch is up and on a different terminal when it is down.
I'm not sure how the Leviton dimmer works, though.
Gary
1helpful
2answers
I just installed a Leviton IP106 Illumatech dimmer switch. It was replacing my existing rotary dimmer switch. The switch is a 3-way wiring job, with another 3-way toggle switch (no dimmer) on the other...
The Leviton IP106 Illumatech dimmer switch must be installed at the switch location where the hot feed exists. From your description your hot feed is at the regular 3-way switch location. Swap locations.
My rotary dimmer doesn't switch 3-ways. I have to push the dimmer button to "on", then I can use the other switch to turn on/off.
You posted under Leviton rotary dimmer.
Lutron and Leviton have many 3-way dimmer styles, and both make 3-way rotary dimmers.
I remember years ago replacing 3-way switches with dimmers and having same experience as you. One dimmer has to be ON for the other dimmer to dim.
Later I learned when you replace both 3-way switches with dimmers, you buy a control-and-companion dimmer set. One dimmer is main, and it lets you dim from both locations. The two dimmers communicate with each other electronically. Buy these dimmers at lighting store that specializes in fixtures and dimmers. Ask for most experienced salesperson.
I checked to see if rotary dimmers are made in the companion set. And neither Leviton or Lutron show 3-way companion set rotary dimmers.
1) Leviton spec sheet on rotary 3-way dimmers does not show companion dimmer. This indicates that Leviton rotary dimmers don't have capability of communicating with each other.
2) Lutron has image of 3-way rotary dimmers.
Image shows single rotary dimmer in 3-way & 4-way circuit.
This tells me that Lutron does not have companion dimmer for 3-way rotary dimmer.
Leviton Dimmer Switch wiring and ceiling wiring for new kitchen table light fixture
I recently purchased a Leviton Dimmer switch which has a brown lead. This switch is to replace 1 of 2, 3 way switches that control the ceiling light in my kitchen. My problem is the new dimmer switch has 4 leads including a brown one which has me confused. I have installed and replaced numerous dimmer switches without difficulty. Please help.
Top Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Electrical Supply Expert? Answer questions, earn points and help others
