Three of four burners on a Maytag Gas Stove/Range/Oven spark but do not ignite even though there is gas flowing. The fourth one always works however. All three went out at the same time.
Replace the "igniter switch assembly". The igniter's are getting a weak spark and since you have one that will not spark at all, this is the usual problem. Here is the assembly to order.
The part comes with a 365 day, any part, any reason return policy.
Gas range repair aid -such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
Clean the burner with a wire brush around where the ignitor is. it needs a proper ground to ignite. When you turn the burner on do you hear a click click click? If so this should solve the problem.
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven
work fine. The griddle just stopped working, no spark. Turning on the
griddle control, the gas valve opens(hear it), gas flows (smell it),
but the ignitor will not spark (no loud or faint spark that I can
hear). I got a replacement ignition device (mount at the burner)
thinking it might be the problem, but still no spark. I checked the AC
voltage at the terminal and measured 39 VAC between the terminal and
ground. Not sure if that is the correct voltage. Any insights or advice
would be great.
sounds as if one of your spark switches ( mounted on the gas valve itself) has shorted out, repalce the switch assembly, comeswith all foure sp[ark switches, easy enoough for you to do
Does this oven glows before igniting the gas in the oven? if it does this unit uses a glow bar ignitor in the oven and spark module for the top burners.If it you dont see the spark( or hear the ticking sound the there will be no ignition. Do you smell gas even if there was no ignition happening? If there's gas that eliminate your gas regulator. If it's only one burner with spark but gas won't come on then your gas valve is deffective. But if there's gas and no spark ten it could be poor grounding, wiring, connection or switch or even spark module problem. You to need call your local Appliance service provider on this one. I do not recommend anyone fixing gas related problem if they are not a qualified servicer.
