SOURCE: Euro pro steam iron model G6118H
the preasure tank inside the iron could have a hole or the holes at the bottom of the iron are clogged up and needs to be cleaned.good luck
SOURCE: euro-pro EP1005 iron--iron heats -blower works-but no steam
You may not need a new iron, my wife's iron is doing the same thing. take the top of the ironing board off (you will need a torx t-20 security bit driver), under the tank is a connection that may have rusted out re-connet it and turn the iron on. Once it heats up, check the tank for leaks. The tank may need to be replace as well or try a 5-minute epoxy type glue on the leaks once it has cooled. If the tank leaks you will get not get enlugh pressure building up to get the steam.
