If you lift up the rear end and hit the foot pedal do both wheels spin?
no only the right tire spins
thats what the problem is, when only one motor is working they don't move at all, so now we need to determine why the other motor isn't spinning. Do you own a multimeter? if not you can pick one up at a local hardware store for about $10, we'll need to check and see if voltage is getting back to the other motor
you want to call me and i can walk you through it?
SOURCE: Rear wheels-
Both wheels should spin in 2nd gear. Only one wheel may spin in 1st, but if you put a little pressure on the one wheel that spins it should make the other wheel start spinning.
But both wheels should spin in high gear at the same time.
Hope this helps. If there is more help you can also ask these guys at this website. http://www.shopjandl.com/ I get my parts from them and they seem to also work on them as well
SOURCE: wheel spinning / traction issue on toy gator
First off, keep in mind that there are reasons why they make the wheels of this slipper plastic - like reducing the risk of burning out the motor. That said, you know those rubber pedal extenders for infants (the things that come with 2 wooden blocks and a large rubber band, they 'may' be big enough to stretch around your wheels. Also have a look around for LEGO rubber tracks. There are some out there that may be large enough as well. Check here.
SOURCE: gator lt wheel doesn't turn when in grass/ slips easily and need
You could try new wheels if those are worn. Otherwise, Google "Gator Traction Bands"- an aftermarket company that makes bands just for these wheels.
If you need the tires, we can help.
http://www.rungreen.com/john_deere_peg_perego.html
Just the Right wheel spins
