I get an inital start with the washer, then about 1 minute later the washer filled with water and then stops with an error code of LE..the motor make a low pitch noise when turning also
Error OE appears after about 10 minutes into a cycle. "OE" in the manual says filter clogged....we have checked & cleaned all of the lines/filter. Now we hear a light humming instead and the washer isn't doing anything...
The motor sensor has failed and needs to be replaced. You will need to call a qualified LG technician to repair this problem.
