It sounds like the actual button switches are going bad. Those would normally be replaceable id you can find an electronic tech that is competent. The internaal backup battery may be bad causing loss of the songs. One would have to look at the switches and find a substitute supplier. These switches are often very tiny about the size of a pencil eraser and are actuated by the larger buttons on the panels. You can probably find them at Digikey.com or Mouser.com. They typically cost about 30 cents each... Disassembly and desoldering and soldering qill be required. The internal parts of the switches wear out.
