I am not sure if you know what the "nut" is... it is the little bar that the strings go over after they leave the tuners. If this is what you are refering to, the "nut" just rest at the end of the fret board and is held in place by string tension. You orient it so the one flat side goes down and rests on the neck and the other flat side rests agains the fret board end. You USUALLY do not adjust this unless the string height is wrong at the end of the neck nearest the tuners. Essentially you just seat it and then the string tension holds it in place... The only adjustment available is to lower it by taking material off by sanding OR to put a few layers of parchment paper beneath it.
Hopefully this is the nut you are talking about and not the truss rod adjustment which, unless you are experienced, you should NOT attempt to change. If you have disturbed the truss rod, take it to a guitar shop for repair.
