Clean shower head with CLR solution and remove any water saving device as these reduce the amount of hot water volume needed to be pulled from tankless heater.
P1 error code is not enough water flow to operate the unit: increase water flow to unit.
http://waterheatertimer.org/pdf/Rheem-Error-code-P1.pdf
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Error codes are considered start-point for troubleshooting.
Page 18 of maintenance manual shows how to clean water filter monthly.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Other causes can include faulty sensor, clogged in-line filter, clogged water softener, sediment in pipe, sediment at elbow, bad check valve, water leak, etc.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
