Patton U2-1487 Floor / Box Fan Logo
Posted on Sep 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My dog ate the cord to the fan I need to know how to replace the old with a new one
Curtis Sewell
Level 3:
  • Master 7,482 Answers
  • Posted on Sep 11, 2011
Curtis Sewell
Master
Level 3:
Answers
7482
Questions
Helped
1941878
Points
24946
Hi mlh9188
You can replace your cord that was eaten by your dog very easy.
Disassemble your fan.
Be sure to mark how the fan is assembled with an awl or sharp instrument to scratch an alignment scratch on the outside of the motor case before you disassemble it....maybe even take a picture
Once you have the fan disassembled to the point that you can get to where the wire that was chewed is connected to the fan, you will disconnect the wires from the plugs,sockets,etc...take another picture before disassembly.
Take the old cord with you down to your local hardware store,loews,homedepot,ace hardware,etc.
Tell the person in the electrical dept what happened, and he will fix you up with a new set up.
Come home install the new cord and plug...keep away from dog...
Please take time to rate me
How do I remove the rear door panel from a 2004 Buick Rainier
If dog ate the old ones, trim away old remaining material and gently pry the panel away from the door's edge. You should be able to see the shaft of the plastic retention clips which are just push-fit into door.
How do i contact Dawnsun to order a new ceiling fan remote?
Dog ate my phone (truly ) .Go on line for manufacturer parts.
Jan 16, 2015 • Dryers
My acer aspire one notebook won't boot up.
Is the new cord/charger/transformer the EXACT same power specs? When your "dog ate your charger", it may have shorted out something in the Laptop? Was it plugged it when your dog ate it?
Have a rule 1800 Pump and my dog ate the cord
so cut repair and tape and fix if its near water side use silicon make sure dosent hit water
I have an older model RCA television ( but it's ot all the hook ups for today) and my dog accidentally ate through the cord, should I take it to a shop or just buy a used tv somewhere else & not even...
I guess it depends how far up the cord your dog ate through it! You could cut the cord off at the bite, fit a new plug and use an extension cord to reach the socket. Other than that, I don't think its an expensive job to get a complete new cord fitted - depending on the repairer, it should still be cheaper than a replacement tv
Dog chewed the gray water mist cord, can i replace the cord?
mcdevito75 here, Best bet, Look for any appliance repair center in your area for replacement electrical line. If your handy yourself or know a handy person, simply match up the electrical cord with another at your local hardware store, Splice the new cord into the old one.
Dog Problem
If it's just the cord that was damaged, you can simply replace the cord
1helpful
I need a power cord for an emerson tv
Hope the dog is well. Best to go to hardware store and buy a plug to replace yourself. Is it two wires, or three? Is it round or flat cable? Also if this is a continuos problem you might want to get a length of metal clad cable to put over the cord before you put the new plug on.
Mike
Broken electrical cord
The belt can e replaced but I recommend you should take it to your local vacuum cleaner service center. They may even be able to fit a new plug on the end for you if the damage is at the plug end.
Top Patton Dryers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Patton Dryer Expert? Answer questions, earn points and help others
