How to change registered owner`s name on Win XP
1- Run regedit
2- Find and go to below key:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\Current Version
3-Change your name in following subkey :Registered Owner
1. as u turn the computer keep hitting F8 key on your keyboard.
2. by doing this you will see advanced boot option.
3. select safe mode by using down arrow key. and press enter key (Return).
3. your computer will be started up in safe mode.. there you will find another user name Admin or Administrator.
4. Click on that if it loads up you can change the password of existing account or you can create another account and use it.
if it doesn't work. you have to re-install the operating system.
The "Recycle Bin" is a name given to a directory that retains the addresses of deleted files and directories. It is normally shon as a link on the desktop. Hope that helps.
When Acer receives a laptop for repair, they assign a case id to that repair item, you must have received one when you handed it in for repair. If you have lost this case id then contact Acer and explain your problem, they should be able to track your repair by the date you handed the laptop in for repair and by your name and address.
Who did you buy it from? Your warrenty should be registered with acer and they can look it up under your name. Here is the direct link to email tech support. Be sure to include all your contact info. that you registered your laptop with and include a phone number. http://acer.custhelp.com/cgi-bin/acer.cfg/php/enduser/ask.php?p_sid=8CJ7En_i
