Washing Machines Logo
Posted on Sep 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore 90 series spins less than full speed, clicks steadily, light on same circiut dims with each click,clothes not wrung dry. mod. #110. 4788291 type 111 ser.#cg5107218
  • ammcdon Sep 12, 2011
    motor winding resistance is within .3 ohm or less of spec. for all 4 specs. clicking seems to be coming from transmission area. noticed no electrical damage or smell.
    thanks. to check clutch and brake, do i remove trans or agitator or both? are these parts going to be available and not too costly?
Anonymous
Level 3:
President:
  • Master 1,554 Answers
  • Posted on Sep 10, 2011
Anonymous
Master
Level 3:
President:
Answers
1554
Questions
0
Helped
611844
Points
4917
The click is most likely coming form the motor control unit(MCU) and the dimming of the lights are caused by the starting current of the motor. It means the motor is being started and restarted repeatedly as the clicks indicates. It is a natural electrical phenomenon for lights to get dim when a motor on the same circuit starts. This is because the motor acts as "short circuit" at start-up drawing almost all current in the circuit.
Unplug the machine or flip the breaker off then remove the rear access panel to have a close view of the motor and the motor control unit on the bottom side. The MCU is where the motor connects to. Plug the machine in and run a spin cycle. Check closely where the clicks are coming from and for any sign of electrical damage such as burning smell and the like. Replace the MCU if it is where the clicks are coming and check also the motor winding resistance. You'll find a Tech Sheet inside the machine.
Please accept the solution should you find it helpful and/or informative. You don't have to rate in order to post comments or additional information. You can still communicate with the expert without rating should you need further advice regarding the issue stated her
  • Anonymous Sep 12, 2011
    The
    issue is then most likely to be an issue with the brake and clutch
    assemblies. The brake shoe assembly must not be fully disengaged during
    the spin cycle and a slight to moderate friction is introduced. This prevents the machine from attaining full spin speed.
    Check the clutch and the
    brake assemblies. The brake shoes must be released completely from the
    brake drum when the motor turns in the spin direction and the clutch tab
    pushes the brake cam driver and release
    the brake to allow the basket to spin freely.
    It looks like the clicking sound is coming from a broken brake cam driver.
    The agitator needs to be taken out including the transmission assembly as the brake and clutch assemblies are mounted to the bottom of the tub and top of the transmission, respectively. The brake and clutch assemblies are both available almost in every parts distributor and they are relatively cheap.
Spin cycle on my Kenmore 90 series makes a clicking sound lights dim
May be high resistance ground in motor or relay. which would be bad news but look for any frayed wires touching the metal cabinet. Hopefully that will be your problem.
try checking your dog ears located under the center post cap. they may be worn and jumping teeth
1helpful
I have a Kenmore 90 series that i have to run through drying cycle twice before the clothes get dry"
try washing the lint screen it gets blocked if you are using fabric sheets
2helpful
2answers
Clothes come out extremly wrinkled on top loding whirlpool washer
This is normal. You can try a lower spin setting or smaller loads. The wrinkles will come out in your dryer.
Kenmore 90 series - clicking during slugish spinning cycle
try your unit on a outlet by it self ,,nothing can be on this line,,sounds like weak ampage,,this machine needs 15 amps line by it self...
Kenmore 90 Series, clothes wet after spin
First thing you need to check is the speed of the spin cycle. As long as you are not overloading the machine, it should spin the clothes pretty dry. the basket drive may need to be replaced. If it is spinning very fast, then check the drain hose, make sure the water is coming out nice and fast. If not you may have a water pump problem even lint clogged inside it.
Problems with Spin Cycle
Sounds like the "out of balance" mech has been destroyed. Check for that first
Alexander
vince
