Kohler Forte entertainment remote valve sink faucet with Sidespray ... Logo
Posted on Sep 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Faucet leaks when i turn off the water I have to pull handle hard to stop leak
Anonymous
Level 2:
Novelist:
  • Expert 92 Answers
  • Posted on Sep 10, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
92
Questions
0
Helped
23609
Points
184
You need a new cartridge is bad and sounds like some junk is inside. You might have lime and even a broken part inside.
I dont think you will be able to fix it this weekend. It is hard to fine parts, if you check your local stores that sell pluming parts they :MIGHT" have the one that fits yours.
I have ot say one nite I had a person where I could not get the parts, but they had the same faucet. So I got the set, took the parts out, got new part fixed like new and took it back.
You go where you have to in talking care of your clients.
Be safe and take care.
Tom
Please take a second and rate us so we know how good of a job we are doing for you. We all can improve, but we need feed back :)
Everpure faucet leaks at handle, how to fix ??
If your Everpure faucet is leaking at the handle, the problem could be a faulty O-ring or a worn-out cartridge. Here are the steps you can follow to fix the leak:
  1. Turn off the water supply: Before you start working on the faucet, make sure to turn off the water supply to prevent any accidents.
  2. Remove the handle: Use a screwdriver to remove the screw that holds the handle in place. Once the screw has been removed, you can gently pull the handle off the faucet.
  3. Check the O-ring: Look for an O-ring around the base of the handle. If the O-ring is damaged, worn or missing, it can cause water to leak from the handle.
  4. Replace the O-ring: If the O-ring is damaged, replace it with a new one. You can purchase O-rings at a hardware store or online.
  5. Check the cartridge: If the O-ring is in good condition, the problem could be a worn-out cartridge. You may need to remove the cartridge and replace it with a new one.
  6. Reassemble the faucet: Once the O-ring or cartridge has been replaced, reassemble the faucet by putting the handle back in place and tightening the screw.
  7. Turn on the water supply: Finally, turn the water supply back on and test the faucet to see if the leak has been fixed.
If you're having difficulty fixing the leak or if the problem persists, it may be best to contact Everpure customer support for further assistance. They can help you diagnose the problem and recommend the best solution.
Feb 11, 2023 • Plumbing
tip
Ball-Type Single Lever Faucets
BALL-TYPE SINGLE-LEVER FAUCETS
  • The single-handle faucet with a ball inside to control both hot and cold water may either leak at the spigot or at the handle. A handle leak is usually caused by improper adjusting-ring tension. Simply adjust the tension to stop the leak. Leaks at the handle can also result from a worn cam gasket. Dripping from the spigot is usually caused by worn spring-loaded, soft rubber seat assemblies.
  • Parts for ball-type faucets are available in kits. Get the spring/seats kit for spigot leaks, or the complete kit for handle leaks. It may be advisable to use the complete kit to replace all working parts of the faucet at the same time. In any case, you'll need a kit containing the spanner/hex wrench for removing the handle (hex end) and turning the adjusting ring (spanner end).
  • Without turning the water off, loosen the handle set screw. Slide the handle from its stem.
  • For a handle leak, try using the spanner wrench to tighten the adjusting collar. Tighten it by turning the wrench and collar clockwise until the faucet doesn't leak when it is turned on and off. If the adjustment is too loose, the faucet will leak. If you turn it too tight, the handle will be hard to move. When the adjusting ring cannot be turned with the wrench, it is corroded. At this point, you will need to remove the cap to free the adjusting ring. (See next step.) You must turn the water off before removing the cap! Apply penetrating oil to the threads, remove the ring and clean all parts before reassembling.
  • Install the seats. For faucet leaks at the spigot, you must install new rubber seats and springs. You must turn off the water to make this repair. Unscrew the chrome cap by turning it counterclockwise. If it won't turn easily, wrap electrical tape around the cap and turn it with pliers. The adjusting ring, which is threaded into the cap's center, will come off with it. For a seats/springs replacement, pull the ball up and out by its stem. The gasketed cam will come with it. Now you can locate the two rubber seats and springs inside the faucet body. Remove them with pliers or yours fingers and install the new ones. The springs go into the holes first, and the cupped sides of the seats fit over the springs.
  • Service the ball. If the ball is dirty or coated with scale, clean it or replace it with a new one. Both plastic and brass balls are available, but use a plastic one if your home has hard water.
  • Reassembly. Put the ball and cam back into the faucet with the slot in the side if the ball fitting over the pin in the faucet body. Then make sure the tab on the cam slips down into the notch in the body. Not aligning the tab and notch is the number one cause for a faucet leaking after it is repaired. Finally, screw on the cap and adjust the ring as described in Step 2. If a properly adjusted ball-type faucet leaks at the cap, the cam and gasket must be replaced.
  • Swing spouts. If a single-lever ball faucet leaks at the base, you should replace the O-rings. Remove the spout-retaining parts, as well as the spout. Wrap the spout-retaining nut with electrical tape to protect it, and remove the nut with a wrench or pliers by turning counterclockwise. Remove the spout by pulling it up and side-to-side. One or more O-rings should now be exposed. Take the O-rings to your hardware or home center store to get matching O-rings for replacement. Clean any scale that appears on the spout base, faucet body, and the inside of the swinging spout. Install the new O-rings and reverse the steps above to reassemble the faucet.
on Jan 16, 2010 • Plumbing
tip
How to repair disc-type faucets
DISC-TYPE FAUCETS
  • Disc faucets may have one or two handles. The water is controlled by openings in the two discs. When the discs are rotated to align, the water flows; when the discs are misaligned, the water shuts off. If the discs wear, the worn discs cause the faucet to leak. Simply turning the handles harder will not stop the leak.
  • To repair a leak in a two-handle disc faucet, turn off the water and remove the handle on the side that's leaking.
  • Use pliers to pull the disc assembly out of the faucet.
  • Beneath the disc unit is the seat assembly, or seal. Replacing this special O-ring may stop the leak.
  • You may need to install a whole new disc assembly for faucets that have been used over a long period of time. In this case, all moving parts of the faucet will have been replaced and should last as long as the original discs did. The parts of some disc units snap apart into a separate bonnet assembly and bottom cap.
  • To repair a leaking single-handle disc, turn off both the hot and cold water and remove the handle to expose the disc assembly. Take out the screws to lift the assembly out of the faucet.
  • You'll notice that beneath the disc unit are three O-ring seals. Though unlikely, water could be leaking between the unit and one of these seals. In this case, you may be able to stop the leak by cleaning the disc assembly and faucet body and installing a new set of seals. If that doesn't work, the entire disc unit must be replaced. This will renew all moving parts.
  • Replacing the unit is fairly simple. Place the three O-rings into their recesses in the bottom of the disc unit. Then install the unit and tighten the screws. Finally, replace the handle–and you're done!
8helpful
How to fix a leaky Moen faucet that leaks at the spout ,which is separate from the handle?
These faucets can leak in three different places:
  1. Internally at the valve seat
    You'll see water dripping from the spout. This means the rubber washer is worn or damaged. To replace the washer, remove the decorative cap from the handle. Remove the retaining screw and pull off the handle. Remove the decorative cover, called an escutcheon, if there is one. Unscrew the packing nut counterclockwise. Unscrew the valve stem and remove it. Remove the screw that holds the rubber washer in place. Because these washers come in many shapes and sizes, you'll want to take the old one to the hardware store and buy an exact replacement. Be sure to buy two washers so you'll have one for the other valve. Replace the washer and reassemble the faucet.
  2. Around the handle
    If you see water coming from below the handle, the packing nut is leaking. Older faucets have a string-like graphite packing material wrapped around the stem. Newer faucets use an O-ring. First try tightening the packing nut clockwise... about one-half turn. If this doesn't stop the leak, remove the packing nut and replace the packing or O-ring; then reassemble the faucet. If the valve is using the graphite packing material, it might be a clue that you should shop for a new faucet.
  3. Between a pivoting spout and the body
    The spout might be held in place with a packing nut, similar to the faucet stem, or it might have a nut at the top of the spout. In either case, remove the spout and replace the packing material or the O-ring seal. Then reassemble the faucet.
Single lever faucets also are known as "washerless" faucets. They are easier to repair than compression faucets after you determine what type of faucet you have. There are three types of washerless faucets: ball, ceramic disk and cartridge.
Leaks are evident in two places... dripping from the spout and seeping from around the spout where it joins the body of the faucet.
Leaks from the spout indicate that the ball, disk or cartridge is leaking. To repair, turn off the water to the faucet, then remove the handle. The handles on ball-type faucets are held in place with a setscrew that requires an Allen wrench to loosen. Ceramic disk and cartridge-type handles usually are held in place by a screw hidden beneath a cap.
On ball and ceramic disk-type faucets, remove the ball or disk and replace the seals. You can buy replacement kits for these faucets at the hardware store or home center.
On cartridge-type faucets, remove the spout and pull out the retainer clip that holds the cartridge in place. To remove the cartridge, pull on the cartridge stem with a twisting motion. If it resists, install the handle so you can a better grip on the cartridge to pull it out. Take the cartridge to the hardware store or home center and purchase an exact replacement kit.
Reassemble the faucet according to directions.
Leaks at the spout-to-body joint indicate an O-ring failure. Disassemble the faucet as described above. Remove the spout sleeve and replace the O-rings. It's a good idea to replace these seals if you have the faucet disassembled for repair of the ball, disk or cartridge.
Constant slow leak
more than likely hot side that is leaking as hot water tends to soften washer...try shutting off hot water angle stop under faucet...if drip stops it the hot water.. try pulling handle off and tightning nut that hold stem in place..
1helpful
Repairing two handle shower faucet with replacement part RP1740 and need a step by step diagram of the repair?? Can't understand how to repair without diagram. Hot water tap won't shut off!
No diagram available, but I should be able to walk you through the process easy enough. First, make sure your water is off and you have relieved the existing pressure by opening a nearby faucet until the water stops running. Then remove the handle. Under the handle there will be a nut that can be removed with an adjustable crescent wrench or water pump pliers (if you use the pliers be careful not to mar the surface.) Make note of which way the stopper for the handle is sitting, this is the raised piece of plastic on top of the stem. Then after the nut is removed, you can use some pliers to grab the center of the stem and pull straight out. Once the stem is out, inside the faucet you will see the seat (the rubber piece) sitting down in a little hole and under that a spring. These two pieces are typically the culprit for the leaking faucet so make sure you replace these as well or the faucet will continue leaking. Then working in reverse order, put the new items back in place and then before tightening the handle in place, turn the water back on and check for leaks at the handle as well as the spout. If you have any leaks, tighten the nut at the handle if that is what is leaking, or turn off the water and start the process again to reposition the seat and spring. Good luck, you can do it.
Aug 17, 2010 • Delta Home
HELLO THE FAUCET DRIPS AT THE HANDLE AND THE HOT AND COLD SEEM REVERSED
On this valve the hot/cold in reverse is easy enough to fix, but the faucet dripping at the handle is another issue. To reverse the hot and cold, turn off the house water, relieve the pressure by opening a nearby faucet. Once the water stops, remove the handle and faucet cover so you can see the valve. then the four screws that are visible need to be removed. Mark one of the screw holes with a crayon or pencil and then remove by pulling straight out. Once out, inspect the main o-ring right behind where it sits against the valve, (if this is damaged, it might be why the handle area is leaking) then turn the whole assembly clockwise 180 degrees then insert straight back in and insert screws. Tighten screws until snug. Turn water back on before installing cover and handle to check for leaks. If no leaks are found, install cover and handle and check for proper position of hot and cold. If there are leaks, tighten screws in clockwise rotation tightening each screw a quarter turn, then moving to the next one until dripping stops. If dripping is from center of stem, where the handle attaches, you will need to contact Price Pfister to request a replacement. They are very good to work with. Good luck.
Faucet is leaking from the cold water line inside the faucet. it is a danze lazio pull out kitchen faucet
Hello
First shut off water to faucet.There should be a allen screw that holds the faucet together near the top back of the handle,lossen this and pull top off.
Next take some pliers and tighten down the lock nuts to compress the washers,do this gently.
Reassemble,water should stop leaking.
2helpful
Faucet hard to pull on and push off
YOU ARE LUCKY, OLD FAUCETS ARE LIKE CLASSIC CARS, INDESTRUCTIBLE. YOUR INNER CARTRIDGE NEEDS TO BE REPLACED OR CLEANED. IN MY EXPERIENCE IF YOU'RE GOING TO GO THROUGH THE TROUBLE TO CLEAN IT YOU MIGHT AS WELL REPLACE IT, BECAUSE MORE TIMES THAN NOT AFTER YOU CLEAN IT, IT WILL START LEAKING. START BY TURNING OFF YOUR WATER AT THE METER, TURN THE FAUCET ON TO BLEED ANY PRESSURE AND VERIFY THAT THE WATER IS OFF. IF THIS IS THE CRYSTAL HANDLE DELTA I AM THINKING OF FOLLOW THESE STEPS: 1. REMOVE THE PLASTIC COVER PLATE IN THE CENTER OF THE HANDLE WITH A FLAT SCREWDRIVER. 2. REMOVE THE SCREW BENEATH THE BEFORE MENTIONED COVER. 3. REMOVE THE HANDLE. 4. REMOVE THE NUT BELOW THE BEFORE MENTIONED HANDLE. 5. REMOVE THE CARTRIDGE, SEATS, STEM AND REPLACE OR CLEAN. 6.FOLLOW THE BEFORE MENTIONED INSTRUCTIONS IN REVERSE MAKING SURE ALL SLOTS AND GROOVES LINE UP. TURN THE WATER BACK ON AND TURN ALL FAUCETS ON TO BLEED ANY AIR IN THE LINES.... GOOD LUCK
1helpful
2answers
Shower handle leak
turn off main water in home . turn on tap some where in home to release presser take shower handle off (screw under cap) unscrew the tap with a wrench unscrew on insides you pull out replace washer put all back togethere
Top Kohler Plumbing Experts
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
