Sony Acid Pro 6 Professional Music Workstation Full Version for PC Logo
Posted on Sep 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't hear the instrumental track when trying to record vocals on acid pro 6. What am I doing wrong?
T-Comtech Repairs
Level 2:
Guru:
  • Expert 417 Answers
  • Posted on Sep 10, 2011
T-Comtech Repairs
Expert
Level 2:
Guru:
Answers
417
Questions
Helped
110997
Points
317
You need to switch the monitor when playback on in the audio properties.
& use headphones to stop any feedback.
I use Samsung C3010. when playing music player, I don't hear any voice. I only hear the instruments. I've tried many airphones but nothing. can it be solved?
How are you obtaining the music that you play on the Samsung C3010? If you're recording the songs yourself, it sounds like you are recording one channel out of phase with the other. This phasing "effect" is how vocal eliminators work. Try playing back music from another source and see if the vocals return.
I am trying to record in multi track mode-want to know how to record for example vocals on track one then without erasing the vocals add for example harmony or guitar so i get two things on one track. At...
How multitrack recording works is assigning each recording to a different track. A way around this is to record the vocals to track one, then your harmony to track two. Save that as a single recording, or mixdown, then open that saved mixdown to track one. You may need to be connected to a computer to do this.
I use the same technique when using Cool Edit Pro (outdated, yes, but I've been using it for 4 years, and I know most of the ins and outs), especially on the guitar tracks, where for studio sound, you've gotta use 4 total tracks. Putting two tracks together frees up your processor, and uses less in the way of effects, as well.
Hope that helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
3helpful
2answers
How do we connect an m audio fast track pro to my pc and mixer (dp-01fx)?
All you have to do is to connect with 2 cables your mixer's output to the two 1/4” TS plus in the front side of the Fast Track Pro and a usb cable from the rear panel of the Fast Track Pro to your pc's usb port. I suppose that you have installed the drivers for Fast Track Pro at your pc.
Anyway in case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Recording with sony acid 6.0
my vocals are off beat when i record why is that.
Tascam 144 sony acid pro 6 no sound from midi track
It sounds like you may be confused on what the MIDI part actually does. MIDI records your performance, not your sound. Then you assign and play back the recorded performance to either a virtual instrument (in which case you should here sound from your computer) or to a real physical MIDI capable instrument (in which case you would here the sound coming from that real instrument instead of the computer).
The ends of the MIDI cables themselves are identical, not IN or OUT.
2answers
Timing problem!! help needed badly!
Your solution is to delay or speed up the sound that your running thru to your computer. The reason why they put user recording latency under the options then preferences then audio settings is not because this never happens or isn't know about. If your sound is too late in the track you have to re-record the track with a higher number try about 125-160. A hint is to play some notes to the beat, check to see that you are in time, then record what you are planning to record.
Not able to record vocals
Make sure everything is routed correctly in Windows. Double click the speaker icon on your taskbar, go into options, click preferences. You will have the option to view playback or recording settings and levels. Select recording and click OK. This will allow you to select which inputs are active for recording.
If it still doesn't work, make sure you have Acid configured to your sound card. I am not specifically familiar with Acid, but all audio programs need to be configured specifically to the system that they're running on.
Boss 900 digital recorder
from reading instructions when you record channel 1 and 2 you are recordind channel 1 in stereo so you only recorded channel 1 try rcording on chanel 3 for vocal hope this helps
2answers
Uploading audio instumentals into the Tascam 2488 II
You can get to the quick start guide here.
www.tascamgiga.com/i-738-232-128-0-BBDFF677.pdf
There is quite a bit to learn to get to the proficient point with this unit. Most of it involves the operator learning the software
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
