SOURCE: security code to pairing my nokia 6126 to my bluetooth devise
if you haven't changed it just type 12345 or until you have to fill up the box
SOURCE: After re formatting my N73 it says unable to
TRY THIS, THIS SHOULD WORK !!!!!
"Unable to perform bluetooth operation"
I tried every way I could to fix this problem.
But no use.
They said if I replace my bt ic, there is an risk. They said sometimes they could fix it, or my cell would be dead.
I didn't take the risk. I bought a tool set my self and opened my handset with care. And fully de-assemble it. I knew where the bt ic is.Then I cleaned it and gave a TINY pressure (be careful, not too much pressure on the mainboard ) on the bt ic. Then I re-assemble it carefully and power on.
BINGO!!! the error comes no more.
I didn't lose any money. Just for the tool set.
Try this folks, I don't know whether it could work on your handset, but give it a try. Save your money and your money.
SOURCE: i have a nokia 5800 music xpress how do i connect
hello thats a silly problem . when you are searching from your mobile the headset must be in pairing mode , instead of just switching on your headset just hold its on button for 10 to 15 sec then the headset will get into pairing mode . and then you can see it on your phone , the default password is 0000 . if u have a manual for your headset it will be a lot clear . just follow those you will get it done.
SOURCE: My Bluetooth device (CE 0979)
Turn off the Bluetooth device and turn off your phone. Turn your phone back On. In your phone go to Bluetooth and remove permission for the device. Re-start your phone. Turn your phone back on and pair your device. The passcode is probably 0000 (four zeros). Once paired it should work properly.
(Note: Make sure your Bluetooth device is fully charged before attempting to pair it.)
