Washing Machines Logo
Posted on Sep 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What sise fuse does a 750w microwave take - Washing Machines
Anonymous
Level 3:
  • Washing Mach... Master 3,361 Answers
  • Posted on Sep 10, 2011
Anonymous
Level 3:
Answers
3361
Questions
Helped
1029254
Points
10654
Firnace burning tht fuse
clean dust out of it check all connections are tight
fuses up to 13 amp 3000w 1500w 5 amp 750w 3 amp
2answers
Where can I buy a replacement 45 amp fuse that goes in the Schumacher 750 watt power inverter?
According to the Schumacher 750W power inverter manual it can take two 40 or 50 amp spade type fuses which can be found on ebay with the link below.
40 amp spade type fuses
Hello iown a schumaker 750w inverter. How do intellect fuse and where are the dudes on this?
You have to take it a part the fuse is in side they should be 30amp two of them.
When i start my microwave it runs for a few seconds then blows the circuit breaker.
You perhaps have too many large appliances running on one particular circuit. Try unplugging everything you aren't using (coffee maker, toaster, etc) and if that doesn't work, I would suggest contacting an electrician to evaluate the circuits in your kitchen. You could also replace high wattage appliances for smaller ones, say a 750W microwave,
I HAVE LOST MY MANUAL FOR MY MICROWAVE UKM128 MICRO 750W
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
1helpful
Does the unit have a fuse. I think i shorted it
Yes, I took this unit apart there are 3 40 amp fuses in the unit. (Similar to blade type car fuses). You have to completely unscrew everything plus take off the top lable and plate to access the other hidden screws
How do I replace the fuses in a 750 watt black and decker power inverter
look for a cover to maybe flip up or slide (most inverters fuses are coverd)
Top Washing Machines Experts
john h
