Its because your phone had not enough memory (RAM)to open those files.
The phone should have enough memory to run the opening process.There should be at least 2 mb of free space in phone itself.
So delete some data from the phone.Try to store all of the data into memory cards.
May be your phones gallery and File manager holding a large amount of data ,which cant be processed by the phones available memory.So delete some data from the phone.
you should try to reset/format your phone,
sometimes we install some applications in phone, it makes unnecessary library files,
it causes problem in normal functions of the cellphone, like Camera not work and stuff like that.
try to remove your sd card and open it in a pc using a card reader... there you can copy the files and transfer it to other disk... maybe its almost full.. make a copy of everything and format your sd card. this will give you more space. 6600 slows down if the memory card is loaded try to remove other files especially large files. a full sd card slows down the cp's performance...
Please go to your nearest repair shop. Ask them to fix your Bluetooth Chipset. Its damaged and need to be replace. The damaged blutooth IC affect file manager and gallery.
if the gallery is saying opening but it is not oening then fillow the folling steps:-
1>take out your memory card & then switch on. if the gallery is opening after taking out the m.m card then again insert the m.m card & delete unwanted &unnecessary softwares from application manager.
