I have had my MP3 Player since December and it has worked perfectly, until the other day I was listening to the radio turned it off, when I went to turn it back on again it displays "incorrect formatt, please reformat player" and then switches itself off straight away.Can you please tell me how to reformat the player and why this problem has occured..Thank you..
my son says his mp3 player wond recognise the new programs on my computer how do i update his samsung mp3 / 4 gig playermy son says his mp3 player wond recognise the new programs on my computer how do i update his samsung mp3 / 4 gig player
i was charging my rca mp3 player to my computer and transferring some songs. I go to listen to it and it implied "error. reformat me "i was charging my rca mp3 player to my computer and transferring some songs. I go to listen to it and it implied "error. reformat me "
I had my mp3 player since july of 2007 and April of 2008 it popped up with a screen saying "Flash error! please back up data and format the player." I do not understand what that means and dont know how to do it. I need help thankzI had my mp3 player since july of 2007 and April of 2008 it popped up with a screen saying "Flash error! please back up data and format the player." I do not understand what that means and dont know how to do it. I need help thankz
AnonymousJun 05, 2008
had the same problem with my LG FM11E - found an LG reformat tool that worked - can't seem to find it on the LG website now though
The zip is called stmp3rec.zip and the install prog stupdaterapp.exe
AnonymousDec 31, 2008
hi i have a philips gogear mp3 player.i copied some softwares.now it is asking to fomat the player.how to do it.please help me.
Formatting is available only while playback is stopped. If the OPR lamp lights red due to low remaining battery power, the player cannot be formatted. All data stored on the player will be erased. The Content Transfer software included with the player will also be deleted. If necessary, download Content Transfer from the customer support web site. The settings of shuffle playback, playlist playback, ZAPPIN playback, and AVLS (volume limit) also return to their defaults.
Follow the steps below to format the Player. 1 Unite the left and right parts to turn off the player. 2 Separate the left and right parts. 3 Press and hold the jog lever for about 15 seconds until the status lamp blinks quickly. Release the jog lever. The OPR lamp lights red. 4 Move the jog lever forward or backward within 30 seconds after the OPR lamp lights red. The status lamp turns off. The OPR lamp lights alternately green and red each time you move the jog lever. 5 Press the jog lever while the OPR lamp lights green. The OPR lamp blinks green quickly and formatting is executed. When the OPR lamp turns off, formatting is complete. If you press the jog lever while the OPR lamp lights red, or if 30 seconds have passed, formatting will be canceled.
Plugging it into another computer changed the formatting of the player.. I would format the player from the menu itself, but if that fails: There are two ways to format an Mp3 player - one on the computer
itself, and one in Windows Media Player. Both methods will end up
erasing all the songs on the player, but the player will be "good as
new" after that. Sometimes reformatting in this manner will override
the player's native formatting and cause problems - this can be
reversed in most cases by updating the player's firmware. Firmware
upgrades are available from most manufacturers' websites. WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or
FAT32. - Connect player to computer, double-click my computer, right
click on icon of mp3 player and select format. This only applies to
Windows-based computers. You can also format the player in Windows Media Player itself: Connect your Mp3 player to the computer and open Windows Media
Player. Click on the Sync tab. Pull down the drop down menu underneath
the Sync tab by moving your cursor over the Sync tab and left clicking
on the little black arrow underneath the Sync tab. Highlight "name of
Mp3 player here 1GB" (wording may vary slightly), and then select
"Format." - this should erase everything. -Tha Mp3 Doctor
or formatting it and starting over, see if that helps
easy way to format
1.Shutdown player 2.Hold Rec button 3.Turn player on 4.Plug your player into the PC 5.Go to My computer 6.Find a Icon named 16Mb Format 7.Open that and make a new text file 8.Name it sansa.fmt 9.unplug player and it will say Formatting..... 10.when its finished it will reset , or shut off, when its done turn it on and see if that helps
I had the excact same thing just turn it on and let the battery run all the way down, then all you have to do is charge it. If this does not work make sure you are running the battery all the way down. Trust me this works.
Good Luck
There has been many of these tyes of errors, i had an error like this myself, i fixed this by formatting my mp3 player, however you could try looking for updates if not format would be your best option.
If there is software for this mp3 player use that to format the player. If there isn't go to "My Computer" look for the mp3 player, prefferably called "Removable drive" right click on that then click on "Format", do that and see if it works after that.
According to page 15 of the Vibe manual, "When formatting in Windows XP, if File System is FAT32 or NTFS, VIBE does not work."
Step 2 under "Formatting VIBE" states: "After setting File system to FAT, press Start button to format."
Don't know if this helps, but, if so, you might want to download the manual from support at pny.com.
Sanddollar
FORMATING AND IT CAN NOT ALLOW THE SONGS TO ENTER
