I opened teh door and thought i felt something hit
Murray, It sounds like one of the door springs has broken and that is why the door seems heavier and opens with much more force.
You'll want to at least make a temporary repair and order a new replacment spring to get your dishwasher working like it should and so it's safer too.
You can check to see which side of the dishwasher the spring broke, by locking the door shut (with the cycle set to "off"). Now remove the lower access panel, beneath the main dishwasher door. There are a couple of screws near the top corner edges of the panel, just under the main door and a couple more on the toe kick near the very bottom.
Once you've got the lower access panel off, you'll be able to see the two door springs, (there is one on each side). Of course, the broken one might have fallen off the spring notches, so look around and you should see it.
With the door still closed and locked, you can remove the broken spring and see if it's just the hook end that broke. If that's the case, you can reform the end hook using a couple pairs of pliers and reinstall the spring on the door and frame mounting points. You'll have to use pliers to stretch the spring slightly to get it on the other mounting point, once you've got one end on a mounting point. If the spring broke off more than 3 coils, you'll need to replace it with a new one.
You can find a replacement by using searspartsdirect.com and putting in your model number to locate a line drawing and parts listing for your particular model. You can also order a new one from them, or use the part number to get one locally, if you wish.
Once you've got the spring back on the door and cabinet mount points, you can unlock the door and gently lower the door to see if everything is working properly. Once you've opened and closed the door several times, you can reinstall the lower access panel and you're back in business.
I hope you find this Very Helpful and best regards!
