Ibanez Ael20e AcousticElectric Guitar with Onboard Tuner Logo
Posted on Sep 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My acoustic electric guitar is giving intermittent sound any idea how to fix this problem
Fred Yearian
Level 3:
  • Ibanez Master 5,603 Answers
  • Posted on Sep 10, 2011
Fred Yearian
Ibanez Master
Level 3:
Answers
5603
Questions
Helped
2250056
Points
16163
A common problem is a WORN jack that is caused by the user NOT looping the guitar cable through the strap or their belt loop. The rotation of the cable as it is played wears both the plug and the jack and causes noise and dropouts. Also verify that the battery connections are corrosion free. Also verify the problem is not with your amp.
2answers
Fishman LBX-001 2006 model. I'm having an issue with my guitar amp. It does not get any sound from an acoustic guitar, I tested my guitar in another amp and it works well. I plug an electric guitar into my...
I am no expert about such things but the electric guitar pickups work with steel strings, wouldn't work if the strings weren't steel - the pickup is a coil of wire and the vibration of the steel string generates an output in the coil the amplifier can work with.
The pickups of the acoustic guitar are presumably glorified microphones that would usually work in a similar fashion to the above, by generating an output but if they are active devices they will need a power supply in order to generate an output, something a standard amplifier input will not provide.
An active device either needs an independent power supply to make the device work like a radio needs a battery or the device will create the output by varying the current flow of the voltage applied across it.
tip
How to Choose A Good Beginner Guitar
Many guitar beginners go for acoustic guitar as their 1st guitar. It not a bad idea to get started with acoustic guitar. Listed here are a few greatest acoustic guitar models you can take into account when you buy your 1st beginner guitar.
Being a Japanese electric corporation, Yamaha began to make all kinds of instruments include guitars and grew to be a brand-new star in the market . Their guitars targeted at all kinds of customers from learners to skilled musicians.An example of the quality affordable beginner acoustic guitars they supplied is Yamaha FG700S. This model has a solid spruce top and laminate sides and back with the good tone just cost you about 200 bucks. Most beginner's acoustic guitars usually have high action that is the gap between guitar strings and fretboard. The sound of this Yamaha guitar models is very excellent regardless of the high action of the factory setting.
Fender is a reputable electric guitar provider and provides consumer with its Fender type electric guitars. Fender acoustic guitar is not just as popular as its electric guitar. Yet the low end entry level line of Fender acoustic guitars are also the number 1 choice for some beginning learners. On most online shopping websites, you could find Fender acoustic guitar. One of the best entry level acoustic guitar model of Fender is the Starcaster acoustic guitar. It owns solid top and laminated back and sides, that is great for its price tag. In brief, Fender Starcaster is an inexpensive beginner guitar.
Alvarez is a guitar brand that is not as famous as other giant companies. The Regent series from Alvarez is affordable as well as built with premium quality. This model has solid top and Dreadnought size. The sound is deep and powerful. You might feel it is a more expensive model if you hear it the first time because the tone is quite distinctive and awesome. The price of Alvarez Regent is about TWO HUNDRED bucks which is very appealing and might be the greatest affordable solid top guitar model.
I will be really pleased if the information above could help you find the perfect entry level guitar model. To get more details on guitar models and brands for beginners, check out Beginner Guitar
on Feb 25, 2014 • Music
2answers
Looking to buy my first acoustic electric guitar, I'm looking at a Martin gpcpa-1 plus with vts or a Taylor 814ce DLX grand auditorium, which is the better guitar
David, you have excellent taste! Both guitars are excellent: Martin has had a reputation as a premier guitar line since 1833- almost 200 years! The Taylor guitar company started in 1974, and is currently (according to Wikipedia, quoting a USA Today article) the #1 guitar maker in America.
I can see why the choice is difficult- they are both Rosewood guitars with Sitka spruce top on a cutaway body, and they are both incredible players.
The Taylor is a little more expensive at $3,999 than the Martin $3,399.
It will come down to which you like better and what kind of music you play- if you record, ask a professional sound engineer which will sound better for your particular style. I happen to like the Taylor neck, but that's mostly because I play a 12- but I cannot see how you would be disappointed with either of these fine instruments.
Action is a bit high. Everyone is saying the DC16RGTE guitar sounds great and gives good volume. I found the one I have is not loud and it has too much boom. Is there a problem with this guitar?
Make sure the guitar CANNOT "HEAR" the amp you are using. Local regeneration (feedback below the level to sustain full feedback) will give a boom sound like in a cave. If you get near enough to the amp for feedback to build up, you can actually see the string vibrating and building up. The loudness has much to do with the amp you connect this too and the settings
Hi! I've a Martin DXME 6 string acoustic guitar and have tension problem how can i fix it?My string set is 0.12-0.52 elixir bronze. Is it possible to adjust it by truss rod?Thanks ct
With that guitar I would recommend taking it to a guitar shop for setting it up. You do NOT want to mess with the truss rod yourself unless you have had experience doing that.
I've got Takamine JJ 325 My problem is backround noise - What can i do ?
Acoustic guitars pickup noise almost like a microphone. You have to prevent the sound from reaching the guitar or get a solid body guitar.
1helpful
I bought my Taylor acoustic/electric brand new. It sounds great, but when i plug it into my amp no sound comes out. I replaced the battery, but it still failed to work. When i plug it in to the amp and...
IF YOUR GUITAR has a built in tuner, make sure the tuner is off as it disables output while tuning... The other thing is to check if you have a volume control on the guitar that might be set too low.. Make sure if you are using 1/4 inch plug guitar cable that it is NOT a TRS balanced cable, as that will turn off the power in the guitar.
Top Ibanez Music Experts
Ngoro
john h
Are you an Ibanez Music Expert? Answer questions, earn points and help others
