SOURCE: TIMEX TX-40BL Clock Radio
If you go to timexaudio.com and select your model, you will find the manual. Best of luck...
SOURCE: timex T601S clock radio
Hi - You can download the manual from the link underlined in blue below:
T601
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
SOURCE: timex clock radio T245S
Try this
http://www.timexaudio.com/pdf/T245_IB37357_46.pdf
Also if the screen is flashing "OFF" toggle the tab on the left
SOURCE: setting time and alarm clock for timex nature sounds clock
Hold the time set key in until the time flashes. Now let it go and use the tuning forward and back keys to set the time. I had the same problem because I continued to hold the timeSet button down while trying to adjust it. If you do, the forward/back keys have no effect.
SOURCE: change time zone
To change the time zone press and hold the time zone button until the number after the Z in the display flases and then release the button (number will still be flashing) and then press the same buttoon and you will see the Z number change to the zone you need. The zones are printed on the top of the clock under the top lid that pops up. My problem is we are in daylight savings time and I cannot get the Eastern Time zone to let me "spring ahead one hour" for daylight saving time!
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Many downloads here, find yours.
There are two ways to find the user manual for your Timex watch.
1. Find your watch on the list below and click on the language link for your manual.
2. Find the 3-digit module number located on the caseback of most Timex products and click on the corresponding language link for that number in the Module Table at the bottom of the page.
