The 4100 is a camera, not a battery charger. Connecting the camera to a computer's USB port is only going to drain the batteries faster, since the camera has to use juice to communicate with the computer (even if only to say it has nothing to say).
If you're using an EN-MH1 rechargeable battery pack, you must charge it using a separate MH-71 battery charger. If you're using rechargeable AA batteries, you must charge them using an appropriate battery charger.
Does it take standard disposable batteries or a rechargeable pack? If the first, check they are inserted correctly as per the illustration in the battery compartment or instruction manual section on inserting batteries. If the second type, recharge the pack. If problem continues check Troubleshooting section of manual or online at Samsung's website.
I'm sorry that the Camcorder is not ejecting tape. Please follow the troubleshooting steps provided below and check the operation:
1. Please make sure that the battery is fully charged.
2. Perform Reset by following steps:
1. Locate the RESET button behind the LCD panel of the camcorder.
2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
3. After 2-3 seconds has elapsed, release the RESET button.
3. Perform a manual power reset by following the steps:
1. Turn off the camcorder.
2. Disconnect AC power adapter.
3. Remove the battery pack.
4. Move the POWER switch to the CAMERA position for 15 seconds.
5. Move the POWER switch to the OFF position.
6. Reconnect the AC power adapter or reinsert the battery pack.
7. Turn on the camcorder.
If the issue persists after following all the steps service will be required. You can find repair information and initiate service at:
http://fixya.com/repair
Thank you for using Fixya. Please let me know if you require any clarifications.
Power off the notebook, remove power cable and battery. Then try inserting a paper clip into the small hold in the CD drive to force eject the tray. Make sure you have powered off device and removed battery before you attempt.
This truly depends on the make and model of your camera. If it uses a rechargeable pack, make sure to fully charge the battery and try it. If this still doesn't work, try plugging it in the computer via USB. If it turns on, then your battery pack may be causing the problem. I would suggest you to bring it to your nearest service center for them to check it out, especially if you still have warranty and so they can replace the battery pack. Some cameras have a reset button at the very bottom (or look into your camera's manual if there is such a thing for your camera) which could be an option as well.
Easy. The same problem faced by almost all Polaroid 600 users these days: the photo pack has a flat battery.
All photo packs are at least two and a half years old now, and all are out of date. The in-built battery will usually be a dead as a dodo or only have barely enough power to eject the protective cover sheet and maybe take a few photos. Photo packs advertised as "refrigerated" will ALWAYS have a flat battery (cold kills batteries) others may occasionally have a battery which will last all ten shots, but the photo chemistry will usually be stale producing harsh contrast, poor colours and possibly too thick for the ejection rollers to squeeze the bag of developer right across the photo.
There is no cure for this, other than to modify the camera to take an external 6v battery or a plug-in adapter, but it's not easy as the camera was never designed to be taken apart. If you search my other answers you'll see that I've given instructions on how to do this many times before.
Sorry, but it's an obsolete camera which is no longer supported and for which the supply of new photo packs has ceased.
I hope that you have still found my reply to be of use and ask only that you return the favour by rating my answer.
This is due to an old photo pack as they're all past the use by date now: the battery built in to it had just enough power to eject the protection sheet and take a photo, but then went flat. There's nothing you can do to remedy this unless you fit an external battery pack. There are no kits to do this with, you have to rig something up on a DIY basis but it is fairly simple with a few basic tools and a little ingenuity. The original batteries were 6v and the camera works at 4.5v; the higher voltage gives a bit of leeway as the battery slowly discharges whilst the film pack is stored and unused.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
you could hit like the method for if a canon won't let you put in a cassette but i don't know if that will work. just hit it on the non screen side a few times and in theory it should work.
