Hi:
The IR receiver inside the television is becoming intermittent and needs to be replaced. You might also check the connections on the receiver small circuit board for cold or loose solder joints.
Testimonial: "I thought that might be the case. Thanks for the help. "
I was in my time a tv service engineer and had many a remote do this the IR Sensor at the top off the circuit board has loose soldered joints But you have to take the remote apart to get to it and in many remotes this is not that essay as they are pressed together and may have screws also so you need to look carefully THE parts that are pressed together ease apart with a flat wide say have inch blade at one side half way down the remote you should hear it pop then ease it all the way round and then look to see if the IR is lose if it is re solder Hope this helps Good luck
