My wash machine will not fill up with water at all, it goes right to the agitate cycle? it also displays a lower caser then an upper case P like so rP. it was going into unbalance mode alot before it stopped filling with water.
thanks in advance, joel
SOURCE: Amana 2002 top loader washer model AlW880QAW
The overload protector is in the motor. Once it heats up, it trips. You likely have something not moving to cause it to trip. Pull your washer forward and tilt it back to about a 45 degree angle. (it will rest against the wall behind it instead of falling forward) Remove the belt and rotate all 3 pulleys to make sure they are moving freely. If the pump pulley (the one on the right hand side)doesn't rotate, you likely have a forign object in there or just a bad pump. If the transmission pulley (the large one in the middle) doesn't rotate, check for forign objectes between the tub and backet. If the one on the left doesn't rotate, it's time for a new motor.
SOURCE: WHIRLPOOL MODEL LXR9445JQ0 WASHER. UPPER
You need to replace the agitator dogs. Yes...there is such a thing. These are four small plastic pieces under the agitator cap that grip the upper agitator, preventing it from back spinning under a load. Searspartdirect.com has an excellent illustration of how your agitator is assembled. Just type in your model number and look under the "Agitator, Basket and Tub" heading. The dogs are listed as item 10 (part #80040). For a bit more you can order the entire upper cam replacment kit (which includes the dogs) as item 9 (285811). For instructions on how to replace, just follow this link:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
This is an expensive and very simple repair. If you require addtional assistance, let me know. I hope this helps you.
SOURCE: amana washer only works on delicate cycle
Open the control panel. Unplug the timer and then plug it back in good and firm.
If it does not work correctly after that,
Replace your timer.
SOURCE: lower agitator spins, upper portion does not
The top agitator dogs are wore out and need to be replaces that is what works the top of the agitator
