SOURCE: Xerox Copier C128 showing Fault
That is a finisher stack height sensor fault. It has not reset when the tray started to lower.
Most commonly that sensor has an arm on it, it will often times fall off. Look around the finisher, on the floor and under the machine for a black part, maybe 2 inches long. Skinny. It is an odd shapped part. It would be sticking out onto the tray, in the middle. It may just be stuck. but my bet is that it has fallen off.
SOURCE: How do I program fax #'s into my machine
Download the user manual from Xerox's website.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
SOURCE: My Xerox Copy centre C123 shows error code 124-315
Thats a weird one. The machine is detecting the wrong speeds.
Try this.
Then look at these 3 locations and see if they match, If they do not set them to match the machine speed.
Testimonial: "Thankyou,and need more help. chose NVM read/write & enter value700-600, it shows 65000 current value what should i enter as new value?"
SOURCE: Xerox CopyCentre C128 Black and
Solution : Power the Machine OFF and ON CAUTION: Wait at least 30 seconds between powering the machine OFF and powering the machine ON. Damage to the optional hard disk could occur.
IF THAT FAILS TRY THIS NEXT:
NOTE: If the machine is equipped with the optional hard disk, the machine remains on for approximately 10 seconds, while storingfiles and preparing for shutdown. The machine then shuts down completely.
Solution : Clear the Paper Jam Behind Cover A
For pictures on this procedure please follow link: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=218,E=0000000002703126506,K=8100,Sxi=4,Solution=obj(1027)
Hope it helps!
SOURCE: my xeros copy centre c128
You can always find your answers at www.xerox.com./support
Two solutions to try:
Related Fault Codes: 047-212, 047-211 Related Fault Codes: 071-210, 072-210, 073-210, 074-210
Links to solutions:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=447,E=0000000002703236606,K=6528,Sxi=8,Case=obj(1908)
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=447,E=0000000002703236606,K=6528,Sxi=8,Case=obj(2119)
Hope it helps!
