Tip & How-To about Ricoh Aficio 1035 Copier
Using Scanrouter Professional on Windows XP SP2 or Vista
Scan Router Professional software will not operate on Windows Vista computers at this time.  It can install on Windows Server 2003.
There have been issues getting Scan Router software to work with Windows XP with Service Pack 2 or higher.  While you might be able to install the software but some features may not work.
The best solution for now to get around this is to install an ftp server on your computer or server.   servu.com has a free one that you can use.
Desktop Binder software will work with Windows XP Service Pack 2 as well as Vista.  Make sure that Windows Firewall is turned off before using it.  If your behind a router with a firewall on it, you shouldn't have it enabled.
Ricoh Aficio 1035 Copier Logo
driver won't work in windows server 2003
Somebody who need windows key click: www.vanskeys.com to got. here i got a working key on my windows about activator. and after i used my windows works properly. hope it help you.
i have installed windows vista and when i try to install nero burning software 6 and nero media player message is displayed it is not compatible with this version of windows what should i do
General system requirements
  • Microsoft ® Windows 98/98SE; Windows 2000 (service pack 4 or later); Windows XP; Windows 2003 server
  • Microsoft® Windows XP Professional x64 Edition (All applications beside InCD and Nero ImageDrive work in the x86 emulator that allows 32-bit Windows applications to run)
  • Microsoft® Windows Internet Explorer 4.0 or later
  • LightScribe support is only available for Windows 2000 (Service Pack 4 or later) and Windows XP or Windows MCE 2004 or greater operating systems
Current version is 10. There are a lot of driver differences between XP & Vista. I'd buy the new version. You could try compatibility mode but I suspect it won't work.
how to use network inventory ? what is it requirment ?
Installed Windows server 2000/2003/2008 on server PC
Set IP address as 192.168.0.1
     Subnet address : 255.255.255.0
     Gateway :  Blank (only if you use router)
      Primary DNS  : 192.168.0.1
      Secondary DNS : Blank
Set up the server as Domain Controller plus DNS server.Here is the link on how to
1) http://www.visualwin.com/AD-Controller/
2)http://www.ssw.com.au/SSW/Standards/DeveloperInstallationNetworkSetup/Windows2003_01DomainControllerSetup-InstallingActiveDirectoryandDNS.doc
Client setting
Set IP address as 192.168.0.2
Here is the link on how to join the domain
1) http://www.petri.co.il/joining_a_domain_in_windows_xp_pro.htm
2) http://www.windowsnetworking.com/articles_tutorials/wxpjoind.html
Client Operating system must be windows xp pro,2000 professional,Vista ultimate etc
2answers
hpqselsk.exe clr error 8004005 & cant open hp director
Its also known as .net framework. Its a software which few applications use for support like chat applications. Below is the system requirement for .net framework to work properly If your system does not fall under the category then you shall uninstall it.
  • upported Operating Systems: Windows 2000; Windows Server 2003 Service Pack 1 for Itanium-based Systems; Windows Server 2003 x64 editions; Windows Server 2008 Datacenter; Windows Server 2008 Enterprise; Windows Server 2008 for Itanium-based Systems; Windows Server 2008 Standard; Windows Vista Business; Windows Vista Enterprise; Windows Vista Home Basic; Windows Vista Home Premium; Windows Vista Starter; Windows Vista Ultimate; Windows XP; Windows XP Professional x64 Edition
2answers
Windows Server 2003 - How can I install Services remotely ?
In my opinion, using Windows Password Reset Software or free Ophcrack is the best method to reset Windows server 2008 password.
Windows Password Reset Software is such software that you can reset forgotten Windows password for Windows 7/XP/Vista by burned CD/DVD/USB. It is professionally designed to reset lost password with less time-consuming and 100% recovery guaranteed. Also it can reset windows password for Windows Server 2008/2003/2000.
If you want to get more information about Ophcrack, please login Ophcrack Official Website.
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
