Question about Goldstar DH504EL Dehumidifier
I have a Zenith dehumidifier P/N 3850A20500H. It was working, and now its not. I cleaned the air filter, and the fan spins just fine when I spin it by hand. Any suggestions? Thanks, Gary
    Brigadier General:
  • 4,736 Answers
Gary, if it's not collecting condensation, there are 5 basic, yet solvable reason s for this. One you have already taken care of - cleaning the filter.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have an analog unit
set the humidity extraction level knob to Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helps you to further troubleshoot and solve the problem. Thanks for choosing FixYa.
Posted on Sep 09, 2011
SOURCE:
Why does blower wheel stop on Frigidaire dehumdifier?
Good Afternoon Desi,
I understand that the blower wheel is not spinning on your Frigidaire dehumidifier, model# FAD504DUD. I also see that the compressor will stay on unless the dehumidifier is unplugged. I suggest you contact the manufacturer for further assistance. They can possibly clarify why the compressor stays on and why the blower fan is not working. If not, they should at least be able to point you in the right direction of having your dehumidifier working. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire FAD504DUD White Energy Star 50...
Zenith dehumidifier is freezing up on the front near the air intake.
check to see if the fan is working. low or no air flow will cause it to ice up. may have to remove the front to de-ice. turn the unit off and slowly pour warm water over the coils to thaw. the water should drain right into the bin. also good to clean any dust off of the coils to keep the air flow open.
Feb 27, 2014 | Zenith Dehumidifiers
Zenith dehumidifier
Depending upon the design, your dehumidifier could be low on Freon.
Dec 31, 2013 | Dehumidifiers
My LG Dehumidfier 3850A20500H has stopped pulling moisture from the air it still runs but no wataer in the bucket what could be the problem? this starts happening after 1 year of purchase.
There are several things that can cause the problem you described. Most of which are easily remedied.
1. The humidity/moisture extraction level is set to high. Lower it to 35%
2, Air intake filter is dirty or clogged. Remove and clean the filter.
3. Refrigerant coils on the back of the unit are dirty and need to be cleaned.
4. Not enough clear air space around the unit. Maintain at least a minimum of 12" of clear air space all around the unit.
5. Unit is operating in a room that has an ambient air temperature at floor level, of between 40 -60 degrees F. Most dehumidifiers don't work well between those temperatures. Raise the unit up off the floor on to something sturdy enough for the weight of the dehumidifier when the bucket is full.
The above are the top 5 things that can cause a dehumidifier not to work properly. Fortunately, none of the solutions require any major repair to the unit.
Hope this helped you to further troubleshoot and solve the problem.
Jun 06, 2011 | LG Dehumidifiers
My GE Dehumidifier fan is working fine, but the bucket is not getting water. I cleaned the filter.
a dehumidifier can only remove water from the air that is humid. have you checked the humidity of the room ti see if it is high or low?
In the winter the average room air is sometimes so dry that one have to add water with a humidifier.
did you check if this is not the case?
Jan 30, 2010 | GE AHG40LA Dehumidifier
Dedumidifyer stopped working. still plugged in PIN# is 3850A20500h
99% of the time, (if compressor still runs), the fan is stuck with dust, or just needs oiling on BOTH ends of the fan motor shaft.
the other 1% will be because your water reservouir presence sensor/switch is not being activated by incomplete insertion of reservouir, or malfunctioning switch.
edgreason@yahoo.com
Oct 03, 2009 | Goldstar DH504EL Dehumidifier
Fan does not work
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Aug 16, 2009 | LG Goldstar LD65EL Dehumidifier
I have a LG LHD45EL and the compressor works, fins chill but fan won't turn at all. I took it apart and cleaned the armature of the fan, Used a non-contact device to ensure electric is present in the...
let the unit cool down
with power on try sticking something in there to spin the fan blade
if it spins and continues to work it is a bad capacitor (little shiny metal can sometimes oval or round)
if it doesnt spin i would have to guess the motor is bad
hope this helps
Jul 29, 2009 | LG LHD45EL Dehumidifier
Fan runs, but compressor does not start
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jul 05, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
Unit is noisy and rattling (70-pint) .....
There is nothing caught in the fan.  I have the same problem.  When taking the back off; unscrew and there our 2 tabs on the to edges about 2 inches in and on the bottom about 2 inches up on each side.  I can't seem to find an answer.   It appears that it could be the motor.  The fan spins freely when I spin it by hand.  I've tried to make adjustments from the fan side.  It looks like I would have to take the condenser coils off to get to the motor  potentially from the front.  Currently, I'm going to live with it because it is in the basement.  It looks like extended warranties are the way to go with dehumidifiers.  My Kenmoore has worked great at pulling water.  The problem has appeared after using a hose set up affecting the drainage.  When I buy another, even though this is my 2nd in 5 years.  But, I am buying the extend warranty this time.   These things break.
May 09, 2009 | Kenmore 54701 Dehumidifier
Goldstar DH504EL Dehumidifier Logo
1,590 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Paul
Paul
Michael Youngman
Michael Youngman
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
