Hitachi HDS721010CLA332 Deskstar 7K1000C SATA2 3GbS 1TB 7200rpm 32MB 0F10383 High Quality SATA II Hard Drive Logo
Posted on Sep 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I purchased my old computer in 2009 and it came with the Hitachi HD, HDS721010CLA332 (0F10383). That computer has failed and I purchased a new HP Pavilion. Can I take the old Hatachi HD and make it a slave drive on my new computer? If so, how and what do I do to make it work? Thank you for your help. Regards, Bill
Anonymous
Level 2:
Novelist:
  • Expert 97 Answers
  • Posted on Sep 08, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
97
Questions
Helped
38567
Points
287
Hi there.
Since your hard drive is a SATA drive, there is no such thing as master and slave drive anymore.
All you need to do is plug it into your new computer (assuming there is an extra slot for a hard drive in there). You will need an extra plug from your power supply that will plug into the hard drive as well as a SATA cable that will plug your hard drive into the motherboard.
Another thing you can do is get an external hard drive enclosure and put it in that. Just make sure you get a SATA one, not an IDE one. I hope this helps.
Dropped Hitachi HD
WOW! Really painful!
CREATE a "backup" folder on your GOOD drive first.
Try this... YOU are trying to get your Hitachi drive to boot and READ! So PLACE your Hitachi Drive in GIVEN position and RETRY booting each time...
VERTICAL (connectors UP).. then connectors down. Will it boot and ACCESS? Try PC board UP, etc, etc... EVERY position you can think of... REBOOTING each time you re-position...
Hopefully ONE of those positions WILL allow you to ACCESS your Hitachi!! As soon as you can, SAVING your most important things first.
IF ALL ELSE FAILS...
Take a look at the photo below... See the chrome 'arm' above the stacked disk(s)? You want to BANG the disk into your palm and hopefully 'free' that "arm" to access your drive again freely! Amigo ~ THIS IS a last resort...
But finally ~ it is written on the Pyramid Walls... BACK IT UP!
Anthony
External Harddrive does not work
Hi:
Hitachi hard drive are junk they are poorly made, but here is an option the could by a bigger hard drive and install it in the External case they are all the same, first take out the old HD from the case and take it with you to the store and purchse the same connection type wether its IDE or Sata and install it in the case, the cases are universal and all most all 5-1/4 inch HD will fit in the case is does not have to be A Hitachi Brand any brand will fit, I recommend a Seagate HD.
5helpful
2answers
Blue spot and vertical smudge in center of screen. Problem comes after tv is running. Tv is Hitachi 50V500A Projection. Thank You
The problem is your light engine is failing. The part number for this is UX22201DR and is available for purchase with the following link. It runs $334 dollars and really is a part that needs to be replaced by a technician due to the complexity in tear down to remove it. Please take a few moments to rate my answer. Thanks...
http://www.partstore.com/Part/Hitachi+Ltd/Hitachi/UX22201DR/New.aspx
Convert internal hard drive to external back-up drive
Greetings
use the cd installer that comes with "Master Cooler"
after successful installation, u can now use the Hard drive.
1helpful
3answers
Hitachi Class Action Lawsuit
I have a 60 inch lcd with the red cloud, bought the tv in 04 called hitachi about it and there sending my tv repair man the light engine no cost. Everyone just needs to call them again. thanks Jim
5helpful
2answers
Drive Lock Password for Hitachi HD in HP Pavilion zv5466ea notebook
probably a little bit late but I think I found a solution ...
1.pull the hard drive out of the laptop
2.boot computer into bios settings
3. set a new bios password and check lock computer
4.while the computer is on slide the HDD in the laptop again.
5. save and exit bios
6.fortunately in the next boot you will get your hdd back
2answers
Black screen
This model has built in multimedia that does not need the operating system (or hard disk) to play movies and music. So it probably is a bad hard drive. Laptop HDs are notorious for failure. That being said, it doesn't take an expert to replace a hard drive and reload the OS and you can get one pretty cheap (<$50) on eBay. DO NOT get a Hitachi or IBM though - my pref is Western Digital or Fujitsu. You will also need the OS disks which you may not have as many systems are putting the install disks on the 1st HD sector. You can usually order disks cheap from HP if you have your purchase info. If you can downlaod and burn an iso image to CD from another computer, the "Ultimate Boot Disk" (search Google) is a great free testing CD.
Digital Conversion 2/2009
No it is not HD ready, your set has a NTSC tuner the new digital sets have an ATSC tuner, BMW Rider
Surround Sound Installation
The Hitachi 50UX57B is a 50 inch standard projection TV with a standard screen. It is not HD ready. If you need it, I think I can download the owner's manual (in PDF format) from Hitachi and foward it to you.
Convergence
You need to most likely replace the convergence output IC's probably STK392-110's and check associated resistors around it. HD is not mandated for 2009, only digital braodcast it is at that point all analog television broadcast must stop.
Top Hitachi Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
vince
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
