The red light flashing is indicating the error.
depending on the make and model of the TV, the duration of the flash and number of flashes determines the error code.
Google the make and model with "blink codes" at the end. Look for your blink code on the website and it will tell you what's wrong with your tv. Make special note of the sequence also.
this could be your LSU often the printer doesnt realise there is a problem untill it starts to print, try downloading smart panel for this model from the samsung website, smart panel will usually give a more accurate error than the 2 lights do
I also have this model. A few months ago, when I turned on the tv, it told me my lamp was in need of replacement. just yesterday, my tv did the same as you....the blue light flashed and then the lamp light kept flickering. All I can say is your lamp needs to be replaced.
Dead with H. output short circuit, replacment blows short again
First check power area and repair dry joints then change all high
voltage (PF value) capacitors in the horizontal section, this fixed the
problem
No power, all standby voltages ok
Replace the guide plus. is located to the side of the tuner
If the TV will not turn on and the red light blinks on the front of the set, it means that the microprocessor has detected a problem in the set and shut the set down. It then blinks the red light a certain number of times, and the number of blinks is the code for why the set has shut off. How many times does the red light blink before repeating?
