Dacor MCS130 Millennia Electric Single Oven Logo
Posted on Sep 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have your oven ( circa 1999 ). Need input as to how long ( minutes ) for self cleaning. Can't find manual.
Anonymous
Level 3:
  • Master 2,341 Answers
  • Posted on Sep 08, 2011
Anonymous
Master
Level 3:
Answers
2341
Questions
Helped
636666
Points
7414
Typically the self clean cycle is set for 3hours...180 minutes
My 2008 Maytag double oven the lower door is locked, no messages on display and the manual says to push 'CANCEL abd Cook & Hold' button but does not unlock the door
f your 2008 Maytag double oven's lower door is locked, here are some steps you can try to unlock it:
Press Cancel/Off Key: Start by pressing the Cancel/Off key. Wait for 20-30 seconds, then try to open the door. Sometimes this simple latch reset can do the trick.
Power Cycle: Turn off the power at the circuit breaker or fuse box for one minute. After that, turn the power back on. Allow the oven to cool for approximately 30-90 minutes, and then move the latch arm to the left to unlock the door.
Self-Clean Cycle Interruption: If the door locked during a self-clean cycle, select the "Self Clean" option, and then choose "Cancel". Wait a couple of minutes, and then try to start the cycle again. If the self-clean cycle was started by mistake, press the Cancel/Off key. The oven will need to cool to around 200°F (95°C) before the door can open.
Remember to ensure that the oven is cool and the power is turned off before attempting any of these steps. Hopefully, one of these methods will help you unlock the oven door! Your manual might prove helpful. Oven is Locked - What to Do - Product Help ' Maytag
Self-Cleaning Door Locked
Would like to download user manual for hotpoint sh83ck
May 02, 2013 • Ovens
1helpful
16answers
Viking deso175ss ran self clean cycle, tried to stop the cycle early. oven door locked wont reset. tried turning power on/off. was able to get door open by pushing latch to left, however it still will not...
Hello, welcome to FixYa.
I understand you have a Vking oven that is not unlocking after stopping (interupting) a self clean cycle, correct ? (I think the letters in the model should be "DSOE" as opposed to deso, aren't they ?)
Though this can cause issue's with the lock mechanism, it is unlikely anything was damaged...in my opinion of course, thus I don't think you need to start swapping parts.
If this hasn't already been done, I would suggest prepairing your oven as if everything was status quo for a self clean cycle.
Close the door, select self clean and let it go through it's start-up and lock sequence. Your going to stop it again, just as Viking instructs pressing "off" which should allow the lock mechanism to properly lock and then unlock.
During the clean cycle the unit usually has to cool before allowing for the door to open which can take up to 30 minutes, (this is why it counts down from 4 hrs even though the cycle is 3.5 hours) but since it should already be cool I'm hoping the lock will go a full revolution to it's normal position.
Normally these ovens will go through a self check sequence upon a power up (if power was lost and then restored...aka "onboard watchdog") which should include the lock assembly rotating to it's unlock position, but they can get out of sequence at times in my experience.
The other method I've tried and had success with is having a secone person hold the door switch closed while power is turned off and then restored a few minutes later.
Let me know if you have tried that and if not try it and get back to me. Hopefully that will restore it's proper function. Good luck.
Regards,
Macmarkus :)
Sep 07, 2011 • Ovens
2helpful
Hi lost the manual..need to start self cleaning
An electric oven is a great oven choice because of the advanced self-cleaning feature often available on certain models. A self-cleaning oven uses high temperatures to clean crusty baking spills and splatters and free its owner from having to use harsh chemicals to clean his oven. The following 4 steps lay out how a self-cleaning oven works.
Step 1 - Setting the Self Cleaning Mode
Depending on the style and brand of oven you own, you start the self-cleaning cycle by setting the oven's operating dial to "Clean," a function that can be as simple as setting a timer knob or pushing one or two buttons.
Step 2 - Cleaning Cycle
Once you have set the self-cleaning cycle, the oven coils-both lower and upper--will begin to heat. These self-cleaning ovens are protected from high oven temperatures damage by heavy insulation installed in their walls and door during the manufacturing process.
Step 3 - Automatic Door Lock
When the oven reaches a pre-determined temperature, the lock on the oven door engages, preventing anyone from opening the door until the oven temperature has cooled.
Step 4 - Removing Residual Ashes
Once the cleaning process is completed, including cooling, you can then remove the residual ash by wiping the bottom oven surface with a damp cloth or sponge.
Hope this helpout
May 17, 2011 • Ovens
2answers
No power on stove after using self clean oven door is locked and cant be open is there a braker swith somewhere
A self cleaning oven that won't open after the self cleaning cycle is usually the oven has not had time to cool down from the high temperatures of cleaning. You should wait at least an hour to open it. You can also try to unplug the unit or turn of the breaker to the over for at least five minutes. You will then have to reset the clock and then try to move the door lock. If that does not work, you can set the self clean cycle again for but only allow it to work for 15 minutes, then cancel the cycle and let the oven cool and then again try to move the door lock or open the door If that does not work, then the lock will have to be accessed and moved manually to open the door
Some ovens need the door to be manually unlatched before the controls are set to the off position before they can be unlocked.
3answers
How do I clean oven
Hi
These are the things you will need to clean your oven.
Oven Cleaner, Soft Rags, Sponges, Oven Cleaner and a Sponges.
Remove oven racks and place them in soapy water to soak.
Preheat oven to 200 degrees.
Turn the oven off and spray the inside with oven cleaner.
Allow to sit for 10 minutes.
  • Read more: How to Clean an Oven | eHow.com http://www.ehow.com/how_2017_clean-oven.html#ixzz0v7mMYimF
    Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
    Dry with a soft cloth.
    Thanks.
  • Step 4 Allow to sit for 10 minutes.
  • Step 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • Step 6 Dry with a soft cloth.
  • Read more: How to Clean an Oven | eHow.com http://www.ehow.com/how_2017_clean-oven.html#ixzz0v7lkil29
  • Step 3 Turn the oven off and spray the inside with oven cleaner.
  • Read more: How to Clean an Oven | eHow.com http://www.ehow.com/how_2017_clean-oven.html#ixzz0v7lanRHk
    4helpful
    3answers
    I cant get my self cleaning oven to unlock... what do I do, I cant find my manual
    Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
    or
    Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
    If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
    Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
    2answers
    How to clean oven
    We called a neighbor who has a similar oven. Thanks for you interest. Utne
    VDSC307-4bss how to operate self-cleaning oven
    I continued a search and found a manual on line... simple process to turn on self-cleaning operation... close the door and set to "clean" ... timer on this model is automatic... runs for 3 1/2 hours.. fan continues for an additional 30 minutes ... open the door and the oven is clean. Thanks
    Top Dacor Ovens Experts
    ZJ Limited
    ZJ Limited
    Paul Bade
    Ngoro
    Are you a Dacor Oven Expert? Answer questions, earn points and help others
