Polaroid TLA-01911C TV Logo
Posted on Sep 13, 2008
How to disassemble polaroid TLA-01911C lcd tv
How do i disassemble my polaroid TLA-01911C lcd tv? i want to replace the lcd panel or it's back light.
  • sheltowee Dec 08, 2008
    No Power. need to disassemble.
  • Anonymous Mar 30, 2014
    polaroid tv tla-01911c need to replace the remote
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Mar 19, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
Helped
5422
Points
23
1) Take the foot off the stand and with a long philips screwdriver remove the single screw that is at the top of the leg (inside leg). Then with the tv facing down lift straight up on the leg.
2) remove the two screws comming from the back of the tv along the bottom edge.
3) With the tv face down on a soft surface ( towel, bedspread, ect).
4) Be carefull with this step it this tv gave me some difficulty and I am experianced with this proceedure. Too much pressure or forcing it too hard will break your case. The back of the tv has a lip which inserts into the face.The face has tabs that lock into slots in the lip of the back. Carefully pry between the face and back pannel (I used my thumbnail and a 1" plastic putty knife.) and slide along the seam until the locking tabs pop loose. Continue sliding your instrument along the seam until all tabs are loose.
5) The back of the tv lifts off of the face leaving all electronics in the face of the tv.
That gets you into the tv. what you do from there is up to you, Good luck;)
Fix sound on Polaroid TLA-01911C TV
Audio amp may be blown. A cable may be bad.
What are you connected to?
1helpful
POLAROID TLA-01911C turns on but only white screen. no sound
Hello
The main board has the fault. Your set need a thorough check before confirmiing the fiault.
This is the picture of the board. OK.
1helpful
Need a manual for Polaroid TLA-01911C
http://www.hdtvreview.com/Polaroid-TLA-01911C-hdtv.html
2helpful
2answers
PROB LEM WITH POLAROID TLA-01911C
The white screen and nothing else usually indicates a failure of the filter capacitors in the power supply board. When these capacitors go out the voltages are not correct so the TV can not power up right. You can rebuild the power board by replacing the bad capacitors and this should bring the TV back to life. Here is a link to a repair guide for this power supply board.
http://www.ccl-la.com/blog/index.php/repairing-a-polaroid-tla-01911c-with-a-bad-power-supply/
I hope this helps,
BuddyMc
3answers
Polaroid TLA-01911C TV - I seem to have the same
You probably have a bad inverter PCB. It is a skinny board by itself over on the left side of the back of the panel.
2answers
Polaroid 19" TV TLA-01911C has no picture. Powers up, see logo
I had the same problem. I replaced 14 capacitors on the Power supply board. I used Panasonic FC series. You could look for swollen capacitors or ones that are oozing. For sure replace these. My set had capacitors that are known to cause problems so I replaced all of them even though I saw no swelling of oozing. Be sure you label all connections carefully when you disassemble.
1helpful
2answers
Polaroid TLA-04011C
Check the powersupply/inverter board for bad capacitors. Also check the CCFL bulbs in the top and bottom for poor solder connection - replace if necessary.
2answers
Will Not Find A Signal Polaroid HD 15" TV - Model TLA-01511C
same (tla-01911c) issue when trying to watch over the air brodcast try rescanning the channels that normally works for me
i got direct tv basic set on my S-video input so i only need over the air when the sat is down (i.e: storms, wind, snow, ...)
Top Polaroid Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
