SOURCE: noisy spin loose drum
drum bearing need need bearing kit and drum support £60 plus labour at similar price. Appliance Doctor
SOURCE: Hotpoint Ultima WMA61 loud knocking noise in spin cycle
Hello I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. Also another way to check is to move the inner durm up and down to see if there is any play in it..
If you need any further advice then dont hesistate to ask....
SOURCE: How to replace drum bearing for hotpoint aquarius+ wf740
My machine is just over 3 years old and although there is no play in the rear drum bearing it is very noisey on spin.
It gets progessively loud the faster the spin speed.
SOURCE: Knocking noise on spin cycle
My machine did the same thing, I found it to be the heater element in the air box had come loose inside the casing and was hitting the sides of the air box. Removed air box from machine and resecured the element now all ok
SOURCE: VERY noisy spin cycle wf860
it sounds like your concrete block is loose. unplug machine and remove lid check block on top of drum there is also 1 at the front of the machine below the door seal. WARNING DO NOT OVERTIGHTEN THE BOLTS.
