i also did the same thing *stupid8 and now when i connect it with the proper charger the screen turns on but it has a hard time starting up and keep cycling between the two opening screens. also slowly turns off when i disconnect, leaving the image to fade away, but i cannot press power to turn it on nor can i turn it off.
You can't post conmments that contain an email address.
Occasionally, the charger might show blinking red right to indicate bad batteries. ... This indicates that the battery already have a full charge. If charging is needed, briefly drain the batteries before trying again. If the light blinks red in about 90 seconds after battery insertion, then the battery voltage is too low.
Hi, it might be the fuse. Does the charge light just flash briefly when you plug in charger? If so it will be the fuse. If the console it out of warranty, maybe you or someone you know can fix it. Check out the following youtube videos Good Luck
Tries buy a new litium battery yet?Get a new adaptor charger?Tries it own website for adaptor charger or Amazon.com,Ebay.com many eclectronics parts excessorries.Tries ur local Radio Shack ask the clerk for help to buy litium battery or charger adaptors.
it does not seems to charge / or turn ON either from the computer or when plugged to an electrical outlet to the wall. Red light is still ON after the whole night . What's wrong ?? Can you please HELP - CODY STELLER MINE IS A 4 GIGA BITE MP4 PLEASE HELP ONLY
If the light doesnt turn to orange after a few minutes on the charger then the problem hardware related. Try another battery if there is no change then there is fault in the device, and repairs are required.
also you can try
this:
1. Plug it in the Charger without the battery inside.
2. switch on the power.
3. Without removing the charger plug in the battery.
we cant see the screen when we put the charger in....please help
