My system is not accepting my sony nwz- b152f walkman. it is charging but not going further for rec etc. it is working on other comp.what is the solution of the problem
http://esupport.sony.com/LA/perl/support-info.pl?Change_Template=1&session_id=ec81aa6514444a2ad4d15f07e9848588&mdl=MHCEX6&info_id=601 CHECK THE ABOVE ADDRESS.
You don't need any driver software, if your pc has windows xp sp2 or later and Windows Media Player 11. If you have problem with your device follow this steps: 1. Connect the player to the computer. 2. From the computer, select start - Control Panel - Performance and Maintenance - System. "System Properties" is displayed. 3. Select Hardware tab, and open Device manager. 4. Open Universal Serial Bus controllers, and select USB Mass Storage Device or WALKMAN NWZ-XXXXX. 5. Select Action - Update Driver ... from the menu bar. "Welcome to the Hardware Update Wizard" is displayed. 6. A dialog on Windows Update connection will be displayed. Select No, not this time., followed by Next. 7. Select Install from a list or specific location [Advanced], followed by Next for the hardware install method. 8. Select Don't search. I will choose the driver to install., followed by Next for the search and install option. 9. Check Show compatible hardware, and then select MTP Device* in the model list, followed by Next. The device driver is installed. 10. "Completing the Hardware Update Wizard" message is displayed, and confirm "MTP Device" message. Click Finish.
Hi, Sony NWZ-B152F does not require any driver, it is plug and play device, Windows has inbuilt drivers for that, just plug it in USB port of computer and Windows will install required drivers automatically. Let me know what kind of driver you are looking for so I might help you for that. Thanks.
i
got an i-pod NWZ-B152F of sony.after connecting to P.C it starts
charging but P.C does not recognise it.i want to transfer songs from my
computer to i-pod.can you please help?
How to turn on/off the power?
To turn on the power
Press the Play/Pause button to turn on the player so that the screen
appears. ? If there is no operation on the player for a certain period
of time while in the stop mode, the display turns off automatically and
the player enters standby status.
I have read this on its operation manual, hope this will help
*If you turn on the Bass function while the equalizer setting is activated, the equalizer setting is disabled. The equalizer setting will be resumed when the Bass function is turned off.
*While the Bass function is activated, you cannot change the equalizer setting.
