SOURCE: Haier 5.0 cu. ft. HCM-050 not freezing
I have the same freezer and recently it quit freezing. The thermostat is my problem. I checked the power outputs to turn on the compressor and it was not there until i tapped on the thermostat. I am currently trying to find another thermostat
SOURCE: freezer
Unplug it and manually defrost it. making sure that the inside of freezer has reached room temprature thenplug it back in and see if that helps.
SOURCE: freezer freezes but does ever stop running
thermostat is stuck on! set to medium setting and gently tap stat. does it turn off? it was stuck. does it still run? its still stuck. if you feel comfortable find stat and power in and out. disconnect - it has to turn off then. but 99 % of the time its the stat. they fail closed and run 24 -7 or fail open and temps get real hot and they never close and restart compressor . yours appears to have failed closed. sometimes you can firmly twist em max cold to min cold a few times and break the stuck contacts and they'll do ok for a while. try to reset at a little higher or warmer temp when done so its not making and breaking on the same old worn spot again. good luck.
SOURCE: Haier HUF138PA-Freezer not freezing
just bought one that a repair man had already been through with similar issues. i wanted it as a fridge so this was no problem. took me about 5 minutes to figure out the reason it wasn't freezing though...the switch at the top that turns the light on when you open it also turns on the fan when you close the door. the door however sits just a tad too low to fully engage the switch. put a piece of tape over the switch and let it cool for 24 hours. chances are this will solve your problem!
