The usual problem of these not being recognized is improper installaation or missing the driver software in the computer. The jacks sometimes appear loose but that can be normal. If you wiggle the jack and there is marginal connections, usually the computer will respond with the USB found and the disconnect tones. If the USB cable has been yanked, then solder could have been broken at the connector. Opening these units one has to be very careful to not damage the cables between the halves of the shell... also keeping track of the screws and type is a must.
