Televison & Video Logo
Posted on Nov 21, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Sharp xr-32x projector. When it is powered up i have little white spots that show up on the screen. I have cleaned the outter lens but the white spots are still present. I beleive there may be dust on the inside of the lens but i do not know how to clen the inside of the lens. Can you please give me some assistance.
Jim's Videos
Level 1:
Habit-Forming:
New Friend:
  • Contributor 16 Answers
  • Posted on Feb 10, 2018
Jim's Videos
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
16
Questions
0
Helped
10401
Points
36
If you see little White spots on the screen on a darker background image then it's most likely that the DLP chip has failed. The sharp xr32 is z DLP projector. The only way to repair it is to replace the DLP chip. I have some good used ones in stock if you're handy repairing things yourself or you can send it to me and I can repair it for you. Just email me at [email protected] for help.
Thanks
Jim
  • Anonymous Feb 10, 2018
    You may want to read the terms and conditions of use before you post more. ... "I can repair it for you at a reasonable price. Please contact me at [email protected]" would be free advertising and not allowed on Fixya
  • Jim's Videos
    Jim's Videos Feb 11, 2018
    Thank you Larry for the advice, I will remember from now on.
Level 3:
  • Televison & ... Master 19,187 Answers
  • Posted on Nov 21, 2017
Level 3:
Answers
19187
Questions
0
Helped
4346470
Points
82261
Any spots that are white are not dust on the output side of the bulb. This is a component failure. IF it was dust it would be dark spots.
5 Related Answers
martin hogg
  • 157 Answers
  • Posted on Jan 05, 2008
SOURCE: HP vp6162 projector spots on projected image
you may have touched the bulb while changing it and minute traces of skin oil are on the actual bulb, with the machine cold, try and very carefully clean the bulb
Anonymous
  • Posted on Jan 25, 2008
SOURCE: blue spots on screen
Obviously this is not the first lamp you have replaced in you projector. These are great projectors however, the LCD panels expire quite quickly. You will find that the spots are related to the LCD panels needing to be replaced. This is not an inexpensive maintainence solution as the panels cost about $1500 each.
Anonymous
  • 4402 Answers
  • Posted on Feb 11, 2008
SOURCE: sony kp57wv600
· Sony Picture tube recall
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Anonymous
  • 563 Answers
  • Posted on Mar 25, 2008
SOURCE: Sharp Notevision XR-10S Multimedia Projector shows pink on the screen
Hi there
If the colour only shows pink when a source ( i.e. vga or video ) is inserted. Firstly check for a faulty cable - 99% it is the problem. Otherwise you'll have to take it to a repairer as the input could be damaged.
Craig Siplin
  • 92 Answers
  • Posted on Jun 08, 2008
SOURCE: sharp projector xr-10x
Just google dlp lamps and you will find dozens of suppliers.
Craig www.classtorations.com
1helpful
I am using Sharp multimedia projector XR-32S-L.There are white spots in the screen. What should I do to remove it?
white spot in image is comman problem of dmd chip it is fixed in to light engieen with heat sink replacment can possiable by expert
I have white spots on my image from my projector SHARP XR-55X?
1,white spots appeared on screen,means the DMD is broken,you need a new DMD. USD200
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
2helpful
2answers
White dots appears in my screen. I replace the lamp and the problem is the same. (Sharp xr32x)
I would be willing to bet the DMD chip is failing the cheapest used one i seen was on e-bay the chip # will be something like 1076-6319W the only part of the # that matters is the last from what i have seen they tell me the 6318W and 6319W is suppose to be the same chip the used on i seen on e-bay was $124.00 probably better off seeking a new projector if you can not replace yourself as you will have over half of the cost involved hope this helps Robert
I have white and black dots that are in the picture we replaced the bulb but didnt take care of the problem any suggestions
my lg325 projector when switched on shows power and ready light but lamp
does not come on. if i press the power switch again the lamp comes on with
3 dotted lines.
I have a Sharp XR-32X. It is not showing up the
It is more than likely a cable problem. If you using a vga cable try replacing it, if not there is something wrong internally in the projector.
1helpful
Abnormal picture
if it's an xr-32x (as it shows on this pic), it's a dlp projector, not an lcd. therefore no green filter. it has only a colorwheel and a dmd chip to affect the color. if it's not an xr-32x, and it's an lcd projector, replace the green filter. sharp sells the parts for the optical engine. but if it was your service tech that did it, have them replace it.
1helpful
My xr-32x has light spots on the projection
Dust in light path. Cleaning required.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
