Invacare Pronto M51 Power Wheelchair Logo
Posted on Jan 07, 2018
I have an older M51 with a toggle switch on/off/on. It seem to be failing. So I replaced it with a standard on/off toggle switch. Now it works if you: 1. Turn it on (nothing happens) 2. Turn it off (all 3 lights turn of) 3. Turn it on (Now you can use the chair) Does this make any sense to you?
gnshome
Level 1:
New Friend:
  • Contributor 31 Answers
  • Posted on Feb 07, 2018
gnshome
Contributor
Level 1:
New Friend:
Answers
31
Questions
0
Helped
9647
Points
41
Yes it does.
The new switch is the problem. The old toggle had a momentary ON when turned on and a jumper wire on two of the three toggle contacts.
5 Related Answers
Anonymous
  • 40 Answers
  • Posted on Apr 16, 2009
SOURCE: My wheelchair Pronto M51 dose not move, the
Are the motors engaged? It sounds like it is in free-wheel
oregoon
  • 175 Answers
  • Posted on Jul 09, 2009
SOURCE: only 1 battery charges
The lights are working, the batteries aren't. Red indicates power to the charger, and it should be on all the time. Green indicates a full charge, usually. If one or both of the batteries are totally dead, then the charger can't "see" them, and you will get a green light, but you will have dead batteries.
All power chairs use sealed, deep-cycle batteries. Deep cycle batteries, are designed for slow amperage dischare over a long time period, unlike a car battery that throws out a lot of amperage for turning the motor over. That's called "cold-cranking amps", and you can load-test a car battery to see if it will throw out a ton of amps for long enough to start a car. There is NO load tester made, or possible for a deep-cycle battery. A load test requires a 24-hour time period, and a complicated formula.
So, your course is to get some fresh, gel-sealed-batteries. You will need type U-1. Specify, gel-sealed-batteries when you go to the battery shop. A fresh set should get the chair up to about 12-16 mile range, which would be about 3-4 hours running constantly at high speed. Good luck.
oregoon
  • 175 Answers
  • Posted on Jul 12, 2009
SOURCE: My wheelchair dose not move
The chair has two levers, one for each motor, that disengage it for freewheeling, or pushing the chair without power. These take it out of gear. Place the levers in the locked, gear-engaged position and it should go for you. Here's a link for the manual for your chair, and it will show you where the location is to place it in gear.http://www.invacare.com/doc_files/1125085J.pdf
Anonymous
  • 103 Answers
  • Posted on Oct 26, 2009
SOURCE: My Pronto M51 chair does not seem to be holding a
Have the batteries load tested. It sounds like the batteries need to be replaced.
Anonymous
  • 692 Answers
  • Posted on Aug 17, 2010
SOURCE: My dad has a mobility
Contact Roadrunner Mobility at 1-800-467-2668. They should be able to help you
We need the schematics, to also put toggle switch for starting
Fitting a toggle switch for starting used to be a budget method of overcoming starter switch and other problems on older cars but will not work where the standard ignition key contains a transponder.
You haven't provided enough detail for a good answer but wiring a (spring return type) toggle switch to operate the starter motor is relatively easy and requires only a battery live and a wire to the starter solenoid or to the coil of the starter relay if you wish to use a relay.
Mostly these wires can be extended from the existing harness to the new switch.
How do you get an older sanyo model number ds27590
I hope it use a remote, cause that's what you use...although some older sets have a 2 way toggle switch like the old 13" Sony trnitron which is located at the bottom of the set..
3answers
Where does the black wire on the valet switch for a older model viper 300 12p pin ongl with gray valet wire
Hello Jesse,
I am not sure what kind of a valet switch that you currently have for replacement, however all viper systems use a two wire connector, with one gray wire and one black wire and a blue connector on the end. All this does when you hit the switch is series, or connect the two wires. The brain reads the number of pulses that is receiving the specified timeframe and then completes the command based on the set number of pulses. This connector is a separate 2 pin connector from the 12 pin main harness. This will be located when looking at the 12 pin harness on the right side of the brain.
M51 charger has solid red light and a blinking green light
Battery is shorted or may have cristlized replace battery. This will solve your problems.
2answers
I replaced my old 3way toggle switches with the LEviton 5613 3way lighted rocker switches. Wired exactly the way the older toggle switches were wired. Switches work fine just like the older ones but one...
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=4044§ion=10103&minisite=10025
The Leviton page for Leviton 5613 does not have a troubleshoot.
Manual shows simple wiring diagram.
3-way switches will not operate lights if switches are wired incorrectly.
Check your ground wire is connected.
Leviton 5613 series is illuminated.
Check that both switches have 5613 number.
Swap switches and see if problem is inside switch.
Radiator fan does not work changed fan motor and sensor
make sure that the wires are tied into the battery, then you might( if all else fails) put a toggle switch in the manually run it. on older carvans the wires get very corroded so that could also be a problem
2answers
I have an IBM thinkcentre m51 that I am trying to upgrade to a dual core processor. It seems that it won't take it. Is there a setting on the bios that will allow the motherboard to support a dual core...
Most major manufactures use motherboard designed to their specs and upgrades to the processor are limited. You can use software such as Belarc Advisor, to determine what motherboard you have and then you can search the net to determine what processors are compatible with it.
Can't toggle between auto, manual, video modes
The switch is an assembly that can be replaced, the question is can you get the part? make a cam off ebay with a busted screen. chances are the board is OK
Power switch failed
well, you have to get the bad switch out and then find another switch that match its specifications. or take it to a repair man and ask him to repair it and change the switch for you. good luck
Top Invacare Health & Beauty Experts
ZJ Limited
ZJ Limited
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
