Define - It attempts to turn over but won't catch and run ???? When you turn the key to start does the starter engage an spin the engine ? This would be a crank no start condition . If the starter doesn't engage an spin the engine this would be a no crank no start condition . Sorry to ask but i have only been an auto tech for thirty years an have heard a lot of different discriptions for these simple actions . crank no start or no crank no start . Very different diagnostic procedures . So when you turn the key to start , does the starter engage an spin the engine ,but won't start an run ?
SOURCE: 2004 yukon xl denali self-leveling rear air shocks
There is a large fuse under the hood in the fuse box that is blown.
SOURCE: location of fuse box/panel for 2004 yukon denali xl
The fuse for the cig lighter is in the fuse panel under the hood on the drivers side. it is marked "cig ltr".
SOURCE: 2005 gmc yukon xl denali service ride control
it has to do with your air ride suspension best bet is take it to the dealer there is probably a problem with a level sensor. hope this helps you
SOURCE: GMC Yukon XL Denali 2004 gauges don't work
GM has an issue with dash clusters since 2002 and the company will not admit to it. We pay $250 each time to swap out the clusters. Let me know what city you are in and I will find you a company locally that replaces clusters.
SOURCE: What the normal transmission temp Yukon Denali XL 2008
TRANSMISSION FLUID NORMAL TEMPERATURE IS 200 DEGREES.
